no boost ?
Old Aug 16, 2008 | 06:15 AM
linx's Avatar
Default no boost ?
I have a b16 with a turbo i am usung a dsm bov and a deltagate with a black spring. I have no boost at the intake. I know the turbo is producing boost because i can here the bov working. I did a pressure test and found no leaks between the intake side of the turbo and the bov b4 the tb. (this is with the intake pipe not connected at the tb but capped off with a presure gauge.) when I try to presurize the system 4 leaks with the charge pipe connected I can here a rush of air (inside the throttle body/intake) but i can find no leaks. I am assuming what im hering is the air escaping thru the valves and out the exhaust.
please helped im stumped still no boost ?
Old Aug 16, 2008 | 12:34 PM
Silva Bullit DC4's Avatar
Default Re: no boost ? (linx)
Are you parked and revving it?
Old Aug 17, 2008 | 04:22 AM
linx's Avatar
no this is using a compressor to presurize system. when test driving it you can here the bov when you let off throttle. there is a leak but i have no clue were
Old Aug 17, 2008 | 10:05 PM
mistahmac's Avatar
check your bov, i had a CDM BOV and it was so shitty, it didn't work at all and created no boost. just leaked it all out.
88 EF Hatch
Aug 1, 2011 02:23 PM
ek_silverback
Mar 16, 2011 10:59 AM
desert eagle
Jan 20, 2005 07:10 PM
InLimbo87
Jul 26, 2004 07:45 AM
Honda Sport
Feb 13, 2004 10:17 AM
