Quick nitrous question
Old Sep 23, 2002 | 05:54 PM
cr-x si's Avatar
Default Quick nitrous question
I am going to buy a dry nitrous system sometime in late winter and i am trying to learn as much about it as i can. My question is, when do you hit the switch to turn on the nitrous? Do you wait till your finel gear? Or do you hit it off the launch? This question might seem real stupid but i need to know. Thanks for th info.
Old Sep 23, 2002 | 06:32 PM
TREVER's Avatar
Default Re: Quick nitrous question (cr-x si)
on street tires in 2 or 3
on slicks in 1 or 2
depends on how much traction you have don't bang the rev limiter on the nos
also only during wot and above 4-5k depending on motor
Old Sep 24, 2002 | 12:13 AM
EndlEEsss's Avatar
Default Re: Quick nitrous question (TREVER)
When i used to run nitrous on my civic, i was always told to squezzeee only on full throtlle.
Old Sep 24, 2002 | 12:15 AM
TypeIII's Avatar
New User
As others have mentioned, only during wide open throttle. That is because without enough fuel in the mixture and nitrous oxide is put in the cylinder, it'll lean out the mixture and cause detonation... Not a pretty thing if you asked me.
Old Sep 24, 2002 | 03:57 AM
Mista Bone's Avatar
D Tranny Guru
answer to all the questions.......
ZEX and slicks.
Old Oct 2, 2002 | 08:33 AM
EndlEEsss's Avatar
Default Re: Quick nitrous question (Mista Bone)
theres a small full throttle switch that you can buy so it ONLY allows you to squeeze at full throttle.
GetawayInMoscow
Jan 4, 2007 04:42 PM
95accordh22a
Feb 26, 2005 08:35 AM
JSpin
Aug 18, 2004 06:50 PM
