Using SS line instead of hardline for direct port?
Old Feb 11, 2004 | 12:39 PM
275Performance's Avatar
Default Using SS line instead of hardline for direct port?
I saw these pics in an archived FI post:
Would there be any issues with using a TFE line instead of the hardlines.
Like a -3 line?
Old Feb 11, 2004 | 12:40 PM
ScrapinSi's Avatar
Default Re: Using SS line instead of hardline for direct port? (275Performance)
would probably be more expensive.
but issues... i doubt it since the main n2o line is steel braided.
Old Feb 11, 2004 | 12:45 PM
Default Re: Using SS line instead of hardline for direct port? (ScrapinSi)
I figured as long as the lengths are conistent, there wouldn't be any problems.
I just had never thought about using lines like that. Pretty interesting.
Old Feb 11, 2004 | 12:59 PM
Silverbeast's Avatar
Aeroquip teflon/SS lines will do the trick. A little pricey, but you get what you pay for.
Old Feb 11, 2004 | 01:06 PM
baphomet's Avatar
Default Re: (Silverbeast)
I was going to do that but reconsidered. I was a little concerned with the lines trying to straighten out under pressure (when spraying) and rotating the nozzles.
If I remember right, I priced it out at ~150 for lines and fitting (-3 AN).
And the 37 degree flare tool + tube bender was ~110. (for the hard line route)
2001ZincSR
Feb 10, 2009 03:05 PM
aj99si
Apr 27, 2005 04:44 PM
jthelman
Sep 11, 2002 01:49 AM
