Nitrous Express Jet questions! please please help
Old Jan 16, 2003 | 09:29 PM
ajshades's Avatar
Default Nitrous Express Jet questions! please please help
ok I've got 5 nitrous jets
18 24 35 41 62
The two circled in red are NX jets the other 3 I guess are NOS jets they have flat heads
is it ok to use the other non NX jets?
how can i figure out about what size hp im injecting using these jets?
i figure i can run a 40 shot *roughly* either with a 35/18 jetting which comes out to be 1.94 and its starting to run lean *or* with a 35/24 witch comes out to be 1.45 which is rich
what is the varience between running rich and lean? i know average mix is Nitrous 1.7/1 Fuel? How far can you go either way?
Old Jan 17, 2003 | 02:27 PM
ajshades's Avatar
Default Re: Nitrous Express Jet questions! please please help (ajshades)
come on guys
Old Jan 17, 2003 | 03:10 PM
GSRwBOOST's Avatar
call NOS and ask them what jet sizes to run with what...
do any of them have the red ruby inside?
those are MUCH better than the plain brass jets.. the ruby doesnt contract with the cold and meters a better nitrous flow for a more consistent flow/shot....
I called NOS when i had problems and they can tell you what jet sizes to use for the shot you want.. then you can adjust the jet sizes for fuel once you know which ones for say.. a 75.... etc.. change the fuel jet up to be a little safe....
lean is bad with nitrous.. melts holes in pistons.. go with a little rich to be safe..
lucava05
Feb 27, 2010 03:22 AM
Soccerking3000
May 19, 2004 06:56 AM
DruWO
May 14, 2004 07:33 AM
KooK
Jul 9, 2003 03:35 PM
integranator
Dec 22, 2002 02:58 PM
