---NITROUS---easy question
Old Dec 7, 2006 | 10:34 AM
butter99's Avatar
Default ---NITROUS---easy question
whats involved in trying to do a <U>50 shot</U> wet direct port kit
..i hear zex makes a 50-200 shot direct/wet.. hows it done??!! jetss??
i want an even distribution est. 50 shot direct port wet kit
Old Dec 7, 2006 | 11:10 AM
HandoEX's Avatar
Default Re: ---NITROUS---easy question (butter99)
I would reconsider going with a direct port system and consider going with a wet kit if you'll only be running a 50 shot. A direct port kit is overkill for such a small shot. And yes, the hp levels are changed by changing the jets.
Old Dec 7, 2006 | 11:43 AM
s2kdre's Avatar
Default Re: ---NITROUS---easy question (HandoEX)
vtec pulls harder than a 50shot, theres nothin better than a 75shot.
Old Dec 7, 2006 | 03:02 PM
Attaus's Avatar
A direct port is good for I4 motors using 100+ jets or 200+ on V8's.
For anything under that, just use a dry kit. A wet kit isn't all it's cracked up to be. The ZEX system, for example, already bumps fuel pressure based on bottle pressure. Worst case scenario is that you have to upgrade the injectors.
Old Dec 10, 2006 | 12:08 PM
integrawow's Avatar
50hp direct port = not necessary
Old Dec 10, 2006 | 02:08 PM
Garage 808 Hatch's Avatar
Default Re: (Attaus)
wet kits are the only way to go. the zex dry kit just has its own rising rate style regulator. the wet kit adds its own fuel by not tricking the fuel regulator. it is the safest way and IMO the only way to go. but for a 50 - 75 shot, a single fogger is just fine. direct port, as stated earlier is really only necessary over 100-125 shot
eg six
May 29, 2006 05:45 PM
MajinB
Mar 20, 2006 05:02 PM
MooreBoost
Feb 18, 2004 10:18 AM
PreludePhill
Jan 28, 2004 10:19 PM
v-tec crx
13
Dec 26, 2001 06:19 AM
