nitrous bottle heater help
Old Apr 3, 2006 | 06:47 PM
Hellraising-vtec's Avatar
Default nitrous bottle heater help
Hi, a friend of my has a nitrous system and wants a bottle heater. I was searching for the best option at an affordible price. He was thinking on the zex that is automatic and maintains the heat by a thermostat or the NX also fully automatic controlled by a pressure controlled transducer. I will apreciatte if you can tell me your opinion or give me another good choice at an affordible price. Thanks
Old Apr 3, 2006 | 08:50 PM
mrbsponge's Avatar
any of the thermostat controlled units are great just nake sure the wiring is to the diagram, or there can be severe issues
Old Apr 3, 2006 | 10:19 PM
97hb's Avatar
Default Re: nitrous bottle heater help (Hellraising-vtec)
Night and day from having a warmer and not.
Old Apr 4, 2006 | 12:30 AM
raceACCORDingly's Avatar
the zex one turns off at a set temp w/ the tstat and sometimes that set temp isnt when the bottle has optimal psi when you add in different variables like ambient temps and how much n2o is left in the bottle.
when i had nitrous i ran the heater blanket straight to a switch and an accessory 12v source where its only on when the cars on. but a while later i got a nx transducer from ebay.
Old Apr 4, 2006 | 03:32 PM
Phase Change Racing's Avatar
The best bang for the buck out there is the unit from Dyno-Tune. Its the same 250W heater that everyone else sells now but its considerably cheaper. you can buy just the heater and run it off a switch (how I like to) or you can buy their automatic pressure setup that is basically the same as NX's and keeps it within 50psi.
Old Apr 4, 2006 | 07:03 PM
TurboLude97's Avatar
Default Re: nitrous bottle heater help (Phase Change Racing)
i acutally have a NX heater thats been sitting around for a while cuz no one wanted it when i posted it up before.. shoot me a pm if your interested.
Not sure if i still have the switch but everything esle (heater, relay, pressure sensor and wiring) are still attached.
Old Apr 4, 2006 | 08:56 PM
Default Re: nitrous bottle heater help (TurboLude97)
thanks for all the help and pm sent
SiMateoAko
Apr 30, 2006 11:04 AM
Hellraising-vtec
Apr 3, 2006 01:42 PM
tegon-gsr
Jan 4, 2004 11:26 AM
TyperDude27
Apr 29, 2002 09:07 AM
TyperDude27
Apr 29, 2002 05:37 AM
