feed line qusestion...
Old Apr 4, 2006 | 12:27 PM
StylishDOHC's Avatar
Default feed line question...
If I run my autometer oil pressure sender and the feed line for my turbo off the same tee on the back of my block will i get an accurate reading?...iv'e looked at sandwich adaptors but i've heard bad about those too.
Old Apr 4, 2006 | 12:34 PM
Soccerking3000's Avatar
Default Re: feed line question... (StylishDOHC)
sandwich plates are fine, as well as "t"ing it off of the back of the block, i use a sandwich plate for my oil pressure sender and the stock oil pressure sender has been removed and my feed line is attached there
Mugencrxsir1's Avatar
Yes you will get an accuate reading, the pressure is the same at the block, and oil filter.
Old Apr 4, 2006 | 07:36 PM
Default Re: feed line question... (Mugencrxsir1)
sweet I thought maybe having the feed line and sender coming from the same source might show a pressure drop on the gauge.
Old Apr 4, 2006 | 08:08 PM
anybody else running it as mentioned? also what kind of pressure range should i be seeing on a B motor (oil hot)?
Old Apr 4, 2006 | 09:02 PM
15-25 at idle and 65-80 3000+
TravisBiggie
Aug 20, 2013 07:48 PM
DannyDeuce
May 2, 2006 01:51 PM
mrbsponge
Sep 25, 2004 04:14 PM
SuzukaBlueAP2
Jul 7, 2003 02:36 PM
Xerxes
Jan 16, 2002 06:53 PM
