nitrous bad for a jrsc...
Old Dec 11, 2002 | 09:44 PM
Mstrpimp02's Avatar
Default nitrous bad for a jrsc...
i was told on another board that nitrous eats the rotors on a jrsc... true or false??
Old Dec 11, 2002 | 09:50 PM
norcalcrx's Avatar
Default Re: nitrous bad for a jrsc... (Mstrpimp02)
I believe it has to be after the charger blades. We are doing a direct port on ours.
Old Dec 11, 2002 | 09:56 PM
Mstrpimp02's Avatar
Default Re: nitrous bad for a jrsc... (norcalcrx)
so nitrous with a jrsc is a no no i take it??
Old Dec 11, 2002 | 10:01 PM
norcalcrx's Avatar
if it is before the tb on say a dry setup i believe(and im could be wrong here) that it eats the coating or causes the coating to come off the charger blades. A direct port nitrous setup is in the im manifold runners after the charger blades so no problems with it affecting the charger.HTH
Old Dec 11, 2002 | 10:02 PM
Mstrpimp02's Avatar
well it's a nitrous express wet kit so would that have any effect on it at all if it wasn't a direct port?
Old Dec 11, 2002 | 10:11 PM
norcalcrx's Avatar
Yes you would need a direct port. This nx kit Part#: 80004EFI
Old Dec 13, 2002 | 06:41 PM
XXXRacing's Avatar
You can run a wet setup before the throttle body. Just don't run more than like a 50-60 shot. If you are going to run more, step up to a 4 fogger setup. Brian
Old Dec 13, 2002 | 09:39 PM
Mstrpimp02's Avatar
Default Re: nitrous bad for a jrsc... (XXXRacing)
i got a hold of jackson racing today and they said that nitrous is just bad for the jrsc unless i run a direct port setup
gosu08
Jul 29, 2008 10:07 PM
gosu08
Jun 13, 2008 01:12 PM
DaNish
Jan 23, 2005 10:50 AM
pm6825
Jun 28, 2003 05:29 PM
jamal-188
Apr 2, 2002 12:54 PM
