code 13...what can i do?
Old Jan 22, 2004 | 05:00 PM
slammin86's Avatar
Default code 13...what can i do?
I keep gettin code 13 (barometric pressure) each morning when i start my car. Is there any way to get rid of this?
It is on a 99 civic si with 440 injectors and a vafc hack.
Old Jan 22, 2004 | 07:16 PM
Meat_Wagon's Avatar
Default Re: code 13...what can i do? (slammin86)
yeah i have the same problem on a 2000 ITR. Its bone stock. In the manual it says its a faulty ecu.
Old Jan 22, 2004 | 07:23 PM
psi420's Avatar
Try disconnecting the VAFC and see if the problem goes away.
Shitty wiring will cause problems.
Shitty = Splices, Taps, Buttconnecters, etc...
Good = Solder and Shrink Tubing
Old Jan 22, 2004 | 09:24 PM
5thgencivic's Avatar
Default Re: (psi420)
If you are getting the code and have a USDM ECU, usually it would mean the ecu needs to be replaced. With hondata it can be disabled. The P28 I have doesn't have a barometric pressure sensor(not USDM), so mine has to be disabled.
sscivicsi
Engine Management and Tuning
May 10, 2009 09:15 AM
B18ceed
May 22, 2006 10:12 PM
schuetts
May 9, 2006 10:55 PM
VanHonda
Sep 18, 2003 09:02 AM
Hondasaurs
Dec 13, 2002 10:42 AM
