Supercharged B18C1, what distance to gap plugs?
I am currently running my iridiums at .025 gap in a S/C'd B18C1 running 6lbs of boost. Should I increase my sparkplug gap to .035 to .038? Anyone running iridium plugs in this setup or something similiar?
Re: Supercharged B18C1, what distance to gap plugs? (Blue-Civic-Hybrid)
Which plugs are you using? When you gap them larger, you will have to replace them more often, but what is a 6$ tune up every oil change...It's no big deal ya know. If you aren't running the bkr7e's then I would reccomend trying them.
Thats right I'm sorry. You already have that posted. I havent' heard too many good things about those plugs. Honestly I would just stick with NGK bkr7e's. I've heard of alot of people saying those aren't that good for FI.
Re: Supercharged B18C1, what distance to gap plugs? (SuperTeg95)
why spend more money on minimal HP (denso) Id rather replace my NGK more often.
fresh tastes better.
Re: Supercharged B18C1, what distance to gap plugs? (jabroni95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jabroni95gsr »</TD></TR><TR><TD CLASS="quote">get rid of those iridiums, they run too hot.</TD></TR></TABLE>
Umm, they come in different heat ranges...
Re: Supercharged B18C1, what distance to gap plugs? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
Umm, they come in different heat ranges... </TD></TR></TABLE>
Doesn't matter. You should use a colder reg copper plug.
Do you know anything about spark plugs? You said iridium plugs run too hot. That statement isn't true. I never recommended iridium plugs for this application, just stating that they come in different heat ranges. The IK22 is the equivalent of a 7 heat range in ngk.
tkHBseries
03-30-2004 10:48 AM
