NGK BKR7EIX-11 Iridium, b-series, 300 whp
There is a lot of information on plugs in the search but no one really talks about using the ngk iridium plugs. For some reason I found a new set of these in my shop, and was going to use them in my gsr-t, around 300 whp. What do you think?
Re: (PrettyLude)
People have talked about them and you will find there not regapable, copper plugs are more suited to race gas if you use that as well.
Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">people don't talk about them because they have success using the regular ngk-r's, and the price is another story also</TD></TR></TABLE>
Yeah, I think the regular NGK ones do just fine.
NGK BKR7E-11 Spark Plugs
Re: NGK BKR7EIX-11 Iridium, b-series, 300 whp (H-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T »</TD></TR><TR><TD CLASS="quote">Iridium spark plugs are the best spark plugs yet to date.... </TD></TR></TABLE>
They are the best, but they way I see it, it's like motor oil. I'd rather change my motor oil more often and use a regular oil filter, than to use synthetic oil and use one of them long drain amsoil filters.
Same thing here. The regular NGK plugs are so cheap, I would rather buy a bunch of these and just change to a new batch of spark plugs every 3 or 4 oil changes.
BKR7E11 is $2.24 per plug at Sparkplugs.com.
COST for FOUR = $8.96
BKR7EIX-11 is $6.95 per plug at Sparkplugs.com.
COST for FOUR = $27.80
It is about 3 times more expensive. I would rather buy the regular NGKs and replace my spark plugs 3 times more often.
Re: NGK BKR7EIX-11 Iridium, b-series, 300 whp (cpforyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou »</TD></TR><TR><TD CLASS="quote">They are the best, but they way I see it, it's like motor oil. I'd rather change my motor oil more often and use a regular oil filter, than to use synthetic oil and use one of them long drain amsoil filters.Same thing here. The regular NGK plugs are so cheap, I would rather buy a bunch of these and just change to a new batch of spark plugs every 3 or 4 oil changes.BKR7E11 is $2.24 per plug at Sparkplugs.com. OST for FOUR = $8.96BKR7EIX-11 is $6.95 per plug at Sparkplugs.com. OST for FOUR = $27.80It is about 3 times more expensive. I would rather buy the regular NGKs and replace my spark plugs 3 times more often.</TD></TR></TABLE>
It's not like that at all with spark plugs.
Go on to Denso's and NGK's webpages and find the offical scientific report and you'll be amazed how crappy other spark plugs are.
civicracingteam
02-17-2005 03:41 AM
hybrid_vtec
15
07-30-2004 01:37 PM
