NGK 9s Racing spark plug problem
Old Dec 7, 2007 | 05:53 PM
jaydim's Avatar
Default NGK 9s Racing spark plug problem
I searched but couldnt find any thing, anyway iam runnig ngk 9s for my turbo gsr but some times it dont want to start, i take out the spark plug and it wet in fuel, every time it does this i have to put a new set otherwise it wont start, do ya think i should run like 8s or some thing, thanks any help please
Old Dec 7, 2007 | 06:03 PM
tony1's Avatar
Default Re: NGK 9s Racing spark plug problem (jaydim)
Are you making 750whp?
Old Dec 7, 2007 | 06:04 PM
jaydim's Avatar
no only making 460 right now
Old Dec 7, 2007 | 07:08 PM
jaydim's Avatar
anyone?
Old Dec 7, 2007 | 08:26 PM
HiProfile's Avatar
Default Re: NGK 9s Racing spark plug problem (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Are you making 750whp?</TD></TR></TABLE>
I think he's infering that you don't need 9's yet. Plugs aren't like turbos - they're cheap enough to run exactly what you need, not what ones that support your eventual goal. They aren't what make power, they just don't make less HP when you use the right plug.
Old Dec 7, 2007 | 11:22 PM
Marlon88's Avatar
I used NGK 8 with my old 400whp setup and worked perfect. check your tuning because if there is alot of fuel at start up your plugs will get washed and there`s your problem...
Old Dec 8, 2007 | 04:34 AM
slow96coupe's Avatar
we were running 7's on my 500WHP hatch... had a problem with 8's starting when it was cool like at night
Old Dec 8, 2007 | 06:08 AM
m R g S r's Avatar
cold plugs foul a lot easier.........switch to 7's or 8's
Old Dec 8, 2007 | 06:37 AM
morgan@synapse motorsport's Avatar
haha my thoughts exactly. Switch to a heat range 7, you would be surprised how far they will get you.
Old Dec 8, 2007 | 12:58 PM
jaydim's Avatar
thanks everyone for 7s do i have to gap them or use oem gap .44
Old Dec 8, 2007 | 02:06 PM
mercutio_07's Avatar
Default Re: (jaydim)
.028-.030
Old Dec 8, 2007 | 05:12 PM
Jared's Avatar
use the largest gap you can use without misfiring
Old Dec 9, 2007 | 04:00 PM
jaydim's Avatar
anyone else
93c1sol
Mar 24, 2023 01:10 AM
intake
Dec 12, 2006 09:16 AM
Doeboy
Dec 21, 2004 03:26 PM
dra600n
Jun 29, 2004 03:20 PM
gassinit
Dec 12, 2003 05:48 PM
