next step from a 60-1
Old Jun 30, 2007 | 03:17 AM
CRX11Z's Avatar
Default next step from a 60-1
i run a b16a stock head/cams/valves with a t60-1 with a 0.63a/r tubine, i run 32psi in the little bugger and have ran a best time of 10.207@144.21mph ( car weighs 1900lbs) looking at going with a bigger turbo, just not sure with which one.
im looking at running a minimum of 150mph and keeping a t3 flange pattern.
what are your thorts on the t3/t67 with a 0.82a/r? or will i need to go bigger to run a 9 sec pass @150mph?
Old Jun 30, 2007 | 03:51 AM
DaveF's Avatar
Default Re: next step from a 60-1 (CRX11Z)
why dont you start with a simple housing swap on your turbine, and see where that can take you ?
Old Jun 30, 2007 | 08:18 PM
CRX11Z's Avatar
you think there is that much gain in housing swaps? 0.82 or a 1.06?
need more hp between 7000-9500rpm!
Old Jun 30, 2007 | 08:39 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (CRX11Z)
****** right it will...
Old Jun 30, 2007 | 09:15 PM
almostboostedgsr's Avatar
Default Re: (oneludesol)
Yes in fact you will get a gain from that. Even though its not a huge step its still a gain.
Old Jul 1, 2007 | 02:15 AM
CRX11Z's Avatar
so go with a 0.82 a/r or straight to the 1.06?
Old Jul 1, 2007 | 05:19 AM
spoolin turbo s's Avatar
.82 and try since its only a 1.6 then run as much boost as you can, if that doesn't get you nines then you know will then need something bigger
i bet a swap to ITR cams would give you 40whp
Old Jul 1, 2007 | 12:07 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (spoolin turbo s)
meh, i would say some stage1 turbo cams with low overlap, and some adjustable cam gears to tune out the rest of the overlap would be better...
Old Jul 1, 2007 | 03:17 PM
nickromeo's Avatar
high rpms love overlap i dont care what anyone says
going to a larger turbine housing will reduce reversion
Old Jul 1, 2007 | 03:43 PM
Jared's Avatar
go with the much bigger turbine at least a 1.06 and some bigger cams. if that doesnt get you where you want to be, then the t4/67 or gt4088r would be a logical choice.
Old Jul 1, 2007 | 05:08 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (nickromeo)
maybe because uberdata sucks fat nut sack... tune with something decent and you will understand what its all about
Old Jul 1, 2007 | 06:52 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX11Z &raquo;</TD></TR><TR><TD CLASS="quote">i run a b16a stock head/cams/valves with a t60-1 with a 0.63a/r tubine, i run 32psi in the little bugger and have ran a best time of 10.207@144.21mph ( car weighs 1900lbs) looking at going with a bigger turbo, just not sure with which one.</TD></TR></TABLE>
Uhm, there's something wrong here, and it's not the turbo size.
89 CRX HF, weighs right at 2000 lbs without the driver due to swap, cage, etc.
84mm B18C
SC44 (.60 T04E/T3 hybrid with .63 AR stage five housing/turbine)
The most I could get out of the car was 477 @ 31 psi, but it made 460+ for the last 2800 rpms of it's powerband which is one hell of a usable chunk of power that doesn't fall off between shifts. Running 27-28 psi it turned a best of 10.38@148 with a 1.78 60', and that was on stock suspension bushings and a couple of mickey mouse suspension hacks. The upgrade for this car is 80% likely going to be a 60-1, and the goal is 9.7-9.8's.
Got any dyno sheets so I could get an idea of the shape of your powerband, videos of the car running, etc?
Old Jul 2, 2007 | 02:52 AM
CRX11Z's Avatar
no dyno sheet sorry!had it on the dyno a while back to give it a quick tune on c16 at 20psi it made 350whp, since then we have been logging it at the track and making adjustments from there....
im rekon its making around 480-520whp at 32psi
Old Jul 2, 2007 | 03:02 AM
Apples vs Orangutans, since the car I'm comparing yours to is an 84mm two liter and no two dynos read exactly the same, but it sounds like you're a bit down on power in the upper boost range since you didn't get time to tune up there. I think you could muscle into the 9's off the current turbo and spending a little time extracting more power from what you have.
It sounds like you want a bit more out of the car and are looking for an excuse to upgrade to a larger turbo, and there is nothing wrong with that. Good luck with it!
Cole89ef
Aug 6, 2009 07:03 AM
bzyq2001
Feb 8, 2009 03:14 AM
the.hamburglar
Jun 10, 2005 08:28 AM
Big Josh
Feb 28, 2005 10:23 AM
pubestripe
Nov 30, 2004 07:01 PM
