WTF is this? LS, installing Blox IM, nowhere to bolt this piece up....
What is this thing? Original IM from a '92 LS motor.
It has coolant running through it (2 ports)
Here's the Blox IM, nowhere to put this thing. Although it has the coolant nipple that attaches to 'the thing'
Also, the stock throttle cable bracket doesn't bolt up, the spacing isn't right. Guess I'll just drill another hole in the bracket to make it work...
Re: WTF is this? LS, installing Blox IM, nowhere to bolt this piece up.... (mahatma)
bypass it, its only a fast idle thermal valve.
If ur car runs fine then it really wont cause problems, maybe a little in the cold.
Just connect the hoses from either end.
yep same as my skunk 2.. manifold.. just use a nipple and a clamp to close the bottom one off and ull be all good... and yes u have to modify the throttle body cable holder... i had to wiht mine..
Re: WTF is this? LS, installing Blox IM, nowhere to bolt this piece up.... (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">bypass it, its only a fast idle thermal valve.
If ur car runs fine then it really wont cause problems, maybe a little in the cold.</TD></TR></TABLE>
Not if you set a colder high idle via IACV in your ECU.
Re: WTF is this? LS, installing Blox IM, nowhere to bolt this piece up.... (Joseph Davis)
hold on, so i just connect them, or block them both off (at their origins)?
saltypants
25
03-29-2010 05:34 PM
4g4dcruisin
06-01-2009 06:56 AM
ApolloSpeed
09-12-2005 04:58 PM
