New set up Idling at 3500RPM.. map sensor problem??
Old Apr 9, 2005 | 04:20 PM
ATgrills.com's Avatar
Default New set up Idling at 3500RPM.. map sensor problem??
Well I finished the install of my new motor...
Basically I took the complete motor set up from a 95 civic SI and put it in my Type R.....
The only part I changed was ... I took off a spoon throttle body and put on a bigger 70MM BBK throttle body..
besides that there is nothing different,, used the AEM EMS from the civic with a jumper harness...
When i started the car everything was fine except that its idling at 2500RPM..
Then i unplued the vacum to the map sensor and now the car idles fine(900RPM)
If i put the vacum line back on the 3 bar map sensor it idles at 2500RPM again..
so I guess its either something electronic that has to do with the map sensor but i know the map sensor itself is ok since i tryed 2 different ones,,,
Could it be something with the EMS that reading a bigger Throttle body??
I dont think its a vacum leak since i didnt find any..
also the throttle bodys are slightly different,, the spoon one that was originally on is for an b16a2..and the BBK is for a b18b... so there the iddle air controle valve under the throttle body on the BBK but not on the spoon!!
would that matter??
PLEASE HELP!
Tyler
Old Apr 9, 2005 | 05:59 PM
Default Re: New set up Idling at 3500RPM.. map sensor problem?? (ATgrills.com)
please help
Old Apr 9, 2005 | 06:17 PM
mtber's Avatar
AEM ems has idle adjustments.. Use them.
Old Apr 9, 2005 | 09:38 PM
Default Re: (mtber)
I dont have a computer to run it nor do i know how to....
but it was fine in the civic,,, so why is it now at 2500??
Tyler
Old Apr 9, 2005 | 10:35 PM
s2kdre's Avatar
Default Re: (ATgrills.com)
when you hook up the laptop to the aem you have to choose which map you have
Old Apr 10, 2005 | 06:41 AM
Default Re: (jdmhonda)
well shouldnt it still be saved from the civic map.. its not like i changed anything...
so ur telling me its no the throttle body or map sensor?
Tyler
Old Apr 10, 2005 | 07:06 AM
tttttt
Old Apr 10, 2005 | 07:13 AM
BoostedEG6's Avatar
check the idle screw on the throttle body, gasket and also check the vac hose going to the map it might have a small crack or something in it.
kr's Avatar
kr
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">AEM ems has idle adjustments.. Use them.</TD></TR></TABLE>
adjust the idle from the ems software and be done with it.
Old Apr 10, 2005 | 01:04 PM
Default Re: (kr)
I put back the spoon throttle body and now its perfect,,
the BBK did not have a idle screw....
thanks guys!
Old Apr 10, 2005 | 01:13 PM
93turbo16's Avatar
vacuum leak, or the BBK was letting air pass, when closed.
Old Apr 10, 2005 | 01:25 PM
Default Re: (93turbo16)
ya exaclty what it was doing!
Hondamonster
Jun 18, 2007 05:49 PM
SVOboy
Mar 26, 2006 11:48 AM
PearlBlueType-S
Jan 7, 2006 09:27 AM
slither
Sep 20, 2005 10:33 AM
comptechgsr2000
May 8, 2002 03:53 PM
