new to boost..is this temp reading normal?
Old Sep 7, 2010 | 02:02 PM
  #51
Freshdot's Avatar
Default Re: new to boost..is this temp reading normal?
the thing with the hondata is that when you do the fan override and set it at like 180 lets say..it turns on and stays on, i might just set it at 190..this way when temps go down to 190 or so it will atleast shut off for a bit.
Old Sep 7, 2010 | 06:12 PM
  #52
SDHonda153's Avatar
Originally Posted by DelSolMarine
get a 13" spal fan, install relay, and 30 amp fuse onto a dual core radiator and your good to go... i would try to get your fan to turn on at like 180.
Exactly what I did. 13" pusher SPAL on a Mishimoto rad set to come on at 180 and a Mugen t-stat. Wrapped my manifold, exhaust, A/C lines and threw a blanket on the turbo and I stay at 179-182 all day long. Get up to about 190 under heavier boost and highway.
Old Sep 7, 2010 | 07:17 PM
  #53
Freshdot's Avatar
^^^ suddenly my 212 doesn't seem to cool anymore.
Old Sep 7, 2010 | 07:35 PM
  #54
Spawne32's Avatar
which spal fans do you guys use? do you have a part #? spal makes alot of different style 13" fans
Old Sep 7, 2010 | 07:41 PM
  #55
Freshdot's Avatar
yea i couldn't find any either, also what kind of mounting hardware are you using? this CXracing setup doesn't look too bad, the CFM is decent and its a 3 row
http://cgi.ebay.com/ebaymotors/CXRac...Q5fAccessories
Old Sep 7, 2010 | 07:43 PM
  #56
97ek-t's Avatar
best thing i did to my boosted teg was went and bought a heater core and stuck it up front by the fmic and just ran my heater core hoses from my stock core to that one and now my car stays at 182-185 all day and its 100degrees here in texas and it dont matter if im at a light or stuck in traffic it dont move! fan comes on at 183 and it hits 185 then back off
Old Sep 7, 2010 | 08:23 PM
  #57
SDHonda153's Avatar
This is the one I'm using, I got it from Tony at T1
13" SPAL - 1710 CFM
Old Sep 8, 2010 | 04:33 AM
  #58
LightningTeg's Avatar
Community Builder
the-fan-man.com
Old Sep 8, 2010 | 07:10 AM
  #59
dpetro1's Avatar
the fan most of us are using is spal part# 30102044 (like SDhonda linked above). you can look on ebay or www.the-fan-man.com as well. remember that you will need to run a new relay to handle the amp draw of the fan.
also www.spalusa.com has a full listing of their products where you can find dimensions and flow charts of every fan to meet your needs.
as far as mounitng, get a shorud and mount it to that. even that ebay fan w/ shroud is probably better than no shroud at all. but i guarantee that cx racing 12" does NOT flow 2100cfm.
Old Sep 8, 2010 | 10:40 AM
  #60
Freshdot's Avatar
the CX racing setup i posted comes with a fan rated at 1200 CFM, the 2100 was referring to RPM's..doesn't the fact that its a 3 row count for anything?
Old Sep 8, 2010 | 12:59 PM
  #61
dpetro1's Avatar
regardless of the radiator you are using, you will still overheat if no airflow is getting to it. thats why a strong fan w/ shroud helps to counter-act the lack of airlfow due to the FMIC blocking up the grill and turbo components heat soaking the engine bay.
im sure that CX racing rad is a decent piece. comboed with a good fan/shroud it will probably work fine. whether or not the included components are up to the job, i cant really say. i know my spal 13" works so im sticking with that.
Old Sep 8, 2010 | 02:37 PM
  #62
Freshdot's Avatar
I'm gonna run the car up in the mountains this weekend and see how temps get..weather is supposed to be really cool. Then make a decision on what to pick up.
Old Sep 11, 2010 | 07:31 AM
  #63
DelSolMarine's Avatar
the current fix right now for boosted hondas overheating is without a doubt the spal fan... it flows more than any other fan on the market... look at guys like tony 1 running around 1000 horsepower and he doesnt even get over 200 degree temp in his car after a pass at the track... the fan clearly has proven its worth...
it also makes our cars sound like an airplane when you pull in a garage!!!
Old Sep 11, 2010 | 07:34 AM
  #64
Spawne32's Avatar
lol my car sounded like an airplane already with the blower, the intake makes a loud whistling sound at idle from all the air being sucked through
Old Sep 13, 2010 | 10:33 AM
  #65
Freshdot's Avatar
well, back from the backroads of PA and happy to report that i only encountered getting close to 220 1 time. I think with the CX radiator set up I should be just fine. I'll let you guys know!
Old Sep 13, 2010 | 10:38 AM
  #66
Spawne32's Avatar
220 is still very hot for these cars, the stock thermostat's are 180
Old Sep 13, 2010 | 10:39 AM
  #67
Freshdot's Avatar
here's a question..what would make this mishimoto without the shroud about 60 bucks more then this CX racing? the CX racing is a 3 row and comes with a shroud.
http://cgi.ebay.com/ebaymotors/MISHI...Q5fAccessories
i don't get it?
Old Sep 13, 2010 | 11:09 AM
  #68
dpetro1's Avatar
i think mishimoto trys to promote themselves as a better quality part. whether or not their stuff is any better than cx racing, i don't know. either way you get a low flowing 12" slim fan. it may or may not help your cooling issues. i dont think the car should ever see above 190 while in motion and 200 when idling. 220 is overheating for our cars.
Old Sep 13, 2010 | 04:02 PM
  #69
Freshdot's Avatar
so is a stock radiator with one of these spal fans the better option?
Old Sep 14, 2010 | 05:11 AM
  #70
dpetro1's Avatar
i think any radiator w/ spal fan AND shroud is a good option. the shroud is key
Old Sep 14, 2010 | 10:28 AM
  #71
Freshdot's Avatar
aright don't shoot me, but i think i'm gonna go for this CX racing, it doesn't seem like a bad setup and I'm in dire need of a new radiator anyway 200 clams doesn't seem all 3 items may not be that bad..i'll be the guinea pig, who knows maybe some other people will benefit off this cheaper setup if all goes well for me lol.
Old Sep 14, 2010 | 11:03 AM
  #72
Community Builder
The 3 row is garbage. I had it and my **** overheated faster then the stock half core Ihad on there. I thought it might have been my setup. but the other guy I sold it to apparently had overheating problems to.
Old Sep 14, 2010 | 12:53 PM
  #73
Freshdot's Avatar
^^^ awesome news, i better change those links i just sent my girlfriend on what to buy me for the bday.
MrBigMac
Honda Civic (2001 - 2005)
May 15, 2016 04:25 PM
CUTTERSPOOL
Oct 21, 2012 11:05 AM
caseyliffick
Apr 7, 2010 02:21 PM
coolusername
Aug 10, 2007 03:52 AM
redacura
Acura TL, RL & ZDX
Feb 22, 2007 06:34 PM
