Neukin EF Turbo setup
Old Feb 4, 2006 | 12:13 PM
88crxvtec's Avatar
Default Neukin EF Turbo setup
I've been working...( Well alex has been working, I have been sending pics and ideas) of a ramhorn for the EF, Using the idea of running the c&r under the radiator support or running a 92-95 half size he came up with a kick *** manifold. I'm proud to have mine be the first off and I'll be posting up pics as I install it later next week.
Here is the clearance I am working with......The C&R 3/4 sits under the stock radiator support with a custom bracket.
Side view of clearance and jim fab x member
Like I said a BIG thanks to Alex at Neukin and a full write up will be coming once it gets here the begining of next week.
My setup
b16 Darton Sleeves 84.5 bore
Weisco Pistons/Eagle 900hp rods
ACL bearings
Balanced rotating assembly
ARP head studs
Golden Eagle Head Gasket
ITR oil pump
OEM water pump and timing belt
Fererra Valves with Omni springs and retainers w/new valve seals
GSR Cams
AEBS Intake Manifold
Modified Drag Charge Piping
Spearco front mount
Precision SC61
c&r 3/4 ef radiator with custom mount
NEUKIN ramhorn manifold
NEUKIN 3inch DP
NEUKIN custom WG tubing
Hasport Mounts
obd0-obd1 mounts
Hondata s200b
Thanks for looking
Old Feb 4, 2006 | 01:08 PM
Turbocivic94's Avatar
Default Re: Neukin EF Turbo setup (88crxvtec)
Looks good
Old Feb 4, 2006 | 03:28 PM
Boosted Chemist's Avatar
Default Re: Neukin EF Turbo setup (Turbocivic94)
nice man, finally got rid of that drag huh?
Old Feb 4, 2006 | 03:56 PM
the.hamburglar's Avatar
Default Re: Neukin EF Turbo setup (Boosted Chemist)
post a pic of that complete engine bay. thinking about painting my block that same color
Old Feb 4, 2006 | 04:09 PM
orion840's Avatar
Default Re: Neukin EF Turbo setup (the.hamburglar)
sweetness
alex is putting out some really sweet manifolds cant wait to see some dyno #'s
88crxvtec's Avatar
here is one for now, trying to get better pics later.
Old Feb 4, 2006 | 09:56 PM
WOW, did you ever think about painting the head?
Old Feb 4, 2006 | 10:21 PM
SiAutoX's Avatar
got a ramhorn on my Bseries EF ....tight fit but looks awsome!! your manifold looks very high quality
Old Feb 5, 2006 | 07:38 AM
seen4ever's Avatar
Default Re: Neukin EF Turbo setup (EF'n Turbo)
good times, looks like it should be a pretty powerful setup at the end of the day.
Old Feb 5, 2006 | 07:42 AM
TURBODC4TEG's Avatar
Default Re: Neukin EF Turbo setup (seen4ever)
wow i didn't know eagle rods support 900hp lol
Old Feb 5, 2006 | 08:05 AM
wade's Avatar
Default Re: Neukin EF Turbo setup (TURBODC4TEG)
bump
Old Feb 5, 2006 | 08:29 AM
88crxvtec's Avatar
Doesn't matter if they support 900, I'm only planning around 350-400, thats enough for me on the street. I plan on driving this not making it a track car.
Old Feb 5, 2006 | 08:30 AM
88crxvtec's Avatar
Default Re: Neukin EF Turbo setup (wade)
Thanks for the comments, hope to start putting it back together this week.
Old Feb 15, 2006 | 12:47 PM
88crxvtec's Avatar
Finally got the manifold in and test mounted, took some pics and then got bronchitius. I hope to get back to final fitting later but some pics and things are looking good.
Side view, this is with the radiator in (under the radiator support) fan does not hit with the sc61 mounted.
Top view after everything was mocked up. Looks clean just need to mount the wg and do some test fitting there.
3inch DP looks good.
I'll post more pics of radiator clearances and such later. Thanks again alex for the manifold. Looks like it will work the way I want it to.
Old Feb 15, 2006 | 03:15 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
SEXUAL!
Old Feb 15, 2006 | 07:01 PM
G
sh!t happens.
Default Re: Neukin EF Turbo setup (boostincoupe)
That is a clean *** engine bay.. Manifold looks good
Old Feb 15, 2006 | 07:16 PM
sloweredcivic's Avatar
how much did it cost and is he planning on producing these?
Old Feb 15, 2006 | 07:47 PM
af-performance's Avatar
Banned
Default Re: (sloweredcivic)
Very sexy piece....
Good job alex.. Props for the clean engine bay!!
Old Feb 15, 2006 | 09:03 PM
Squirtle's Avatar
Bump for price! Sweet mani.
Old Feb 16, 2006 | 05:23 AM
88crxvtec's Avatar
Default Re: (Squirtle)
Alex said they are the same price as the other manifolds, just need to specify that it is for an EF.
Thanks for the comments, waiting for a new gasket for the exhaust and then will be putting everything back together.
Old Feb 16, 2006 | 07:48 AM
92cxturbo's Avatar
Default Re: (88crxvtec)
Thats a nice setup my brother will be running the same setup just a different turbo and manifold if we ever see it to one-fab
are your wires tucked in your bay?
Old Feb 16, 2006 | 10:53 AM
88crxvtec's Avatar
Default Re: (92cxturbo)
I've been reading your posts, sorry to hear your problems but I'm very happy with Neukins work.
The wires are tucked in the car and under the wheels wheels, extended a few and hid the HID ballasts behind the front bumper. I still need to redo a few vaccum lines but I'm very happy with how it turns out.
Old Feb 16, 2006 | 11:05 AM
92cxturbo's Avatar
that's sick im going to try it out will post pics when things start going together
Nice setup man, cant wate to see some numbers on that thing
Old Feb 16, 2006 | 01:22 PM
Tactic$'s Avatar
I believe i bought one of Alex's first ram-horn style manifolds/3" downpipes for my EM1.
Great guy, great service.
JDMmadness
Nov 7, 2010 04:52 PM
WhiteVX
Jun 10, 2009 04:35 AM
88crxvtec
23
Feb 16, 2006 03:23 PM
redzcstandardhatch
Welding / Fabrication
38
Feb 13, 2006 06:24 AM
warfa
Mar 20, 2002 04:24 AM
