your opinions please - exhaust question..
Well, i posted a while ago about my exhaust setup for my turbo sohc (gt28r running 7psi). I have a 2.5" downpipe with 2.5" high flow cat, but couldn't be decesive about exhaust from the cat-back. So ive decided to get with the Apexi N1, but the muffler - not the whole exhaust, cause I figure itll be cheaper to just by the muffler and get it customed piped since the exhaust costs $400 anyway. So my question is whether to get the turbo version or NA version? I know it sounds kinda stupid since im turbo'd, but the turbo version is 3" inlet while the NA is 2.5" and I read awhile ago thats its better to keep a constant diameter all the way back, so then keeping that in mind, which one should I get? Get the 3" and do a 2.5" > 3" somewhere along the custom piping or get the 2.5" all the way back? Thanks...
it wasnt a money issue for getting a 2.5" downpipe, i just wanted to keep my ac. Plus, if im not planning on running alot of boost (maybe 10psi in the future w/mild build), so for now 2.5" should be fine. Ive heard that 3" isn't necessary and could almost be too much for small apps. I was really just wondering if its better to go 2.5" consistently all the way back or 2.5" to the exhaust and then 3" from the cat back?
Re: (sk8shorty012)
Still get the 3" system.....you can easily make a 3" AC compatible downpipe down the road. All you do is use a tiny bit of 2.5" pipe right off the turbo until that first bend by the compressor. Once you make that bend, then you go to 3" all the way back.
