neptune tuners help!
Old Aug 26, 2005 | 06:22 PM
igo4bmx's Avatar
Default neptune tuners help!
my car is bogging like crazy and acting like i have a vacuum leak cuz it can barely idle and when i rev high enough it dies
pressing the gas pedal while the keys are at II on the ignition yields a solid CEL
any thoughts
no vacuum leaks from what i see
Old Aug 26, 2005 | 08:42 PM
mtber's Avatar
Default Re: neptune tuners help! (igo4bmx)
If your vehicle has a solid cel with no srs jumper & with a srs jumper in place, then your ecu is not working properly.
Old Aug 27, 2005 | 05:35 AM
igo4bmx's Avatar
Default Re: neptune tuners help! (mtber)
neptunes bee running for a while...
and cel solid only when i check codes
Old Aug 27, 2005 | 05:38 AM
DaveF's Avatar
check your map sensor.
Old Aug 27, 2005 | 06:15 AM
igo4bmx's Avatar
Default Re: neptune tuners help! (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">check your map sensor.</TD></TR></TABLE>
i did...FYI im running a 3bar map sensor
strangly enough... it sounds like a bvacuum leak...
i removed all lines going to my vacuum manifold, only hooked up the map sensor and plugged every hole in the intake manifold....
stil happenes...
map sensor does see vacuum, from what i see in my datalogs..
but my boost gaujge shows some leak somewherei think (less than 20 inHg vaccuum)
pcv hole plugged
brake booster hole properly connected
cruises control plugged
EVAP purge solenoid plugged
Old Aug 27, 2005 | 06:21 AM
HRTuning's Avatar
Email me a datalog if you get a chance.
Support@HRTuning.com
Old Aug 27, 2005 | 06:27 AM
igo4bmx's Avatar
Default Re: neptune tuners help! (HRTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HRTuning &raquo;</TD></TR><TR><TD CLASS="quote">Email me a datalog if you get a chance.
Support@HRTuning.com</TD></TR></TABLE>
i didn
t save the datalog, but here is the map sensor read out with a couple other things..
Old Aug 27, 2005 | 06:56 AM
DaveF's Avatar
i know this has nothing to do with the ecu, but is it possible that your timing belt jumped a tooth? also, what about something inside the distributer going bad?? icm maybe?
Old Aug 27, 2005 | 07:37 AM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">i know this has nothing to do with the ecu, but is it possible that your timing belt jumped a tooth? also, what about something inside the distributer going bad?? icm maybe?</TD></TR></TABLE>
i'll have to look...
Old Aug 31, 2005 | 09:02 AM
igo4bmx's Avatar
bump for any other ideas..
i have been busy all week, but here is what i will check
timing
vacuum lines will be revisited
possibly creating a boost leak tester.
any other ideas will be appreciated!
my friend with a DSM had an idea... does neptune run its maps like a maf setup? (i.e. would a blown off charge pipe do this like on a DSM?)
Old Aug 31, 2005 | 10:48 AM
HRTuning's Avatar
Default Re: (igo4bmx)
No that would not cause it, you are not running a MAF.
Old Aug 31, 2005 | 10:50 AM
igo4bmx's Avatar
Default Re: (HRTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HRTuning &raquo;</TD></TR><TR><TD CLASS="quote">No that would not cause it, you are not running a MAF.</TD></TR></TABLE>
good thanks.
§95HATCH§
Apr 6, 2009 12:40 PM
Clayton
Nov 28, 2006 07:36 PM
jay-d-em
Sep 7, 2006 05:07 PM
sakums20
Apr 29, 2004 02:40 PM
FourthGenHatch
May 19, 2003 10:51 AM
