Negative voltage on O2 sensor
Old Aug 8, 2002 | 10:30 PM
ion_four's Avatar
Default Negative voltage on O2 sensor
I'm assuming that when the voltage is negative that means that the engine is running absurdly rich? I just got my turbo in and am running NO downpipe, and have the O2 sensor right on the turbine outlet. It's showing me a negative voltage alot and I'm not sure what to make of it. I'm running dsm 450's and a circuit that scales the MAP sensor output ala. VAFC hack. I still need to tweak the circuit, but I'm not 100% sure which way to go. My EGT doesn't go above 1000º on short pulls (I'm not boosting yet) and the turbine has alot of black soot on the inside...
So, I guess I'm runnin really rich?
How long do you have to run really rich before you mess up the sensor? I just installed it and don't want to beef it.
[Modified by ion_four, 7:31 AM 8/9/2002]
Old Aug 9, 2002 | 10:07 AM
filetofit
Guest
Posts: n/a
Default Re: Negative voltage on O2 sensor (ion_four)
http://www.shotimes.com/SHO3badO2sensor.html
pauld
May 31, 2008 08:40 PM
Maxime
May 17, 2004 11:30 AM
nautica_t
Mar 30, 2004 10:09 AM
tonylude94
Aug 21, 2003 01:26 PM
samagon
Feb 25, 2002 01:49 PM
