NEED YOUR ADVICE
Old Feb 22, 2013 | 08:08 PM
gpr's Avatar
gpr
Default NEED YOUR ADVICE
Hi guys need your advice. I currently have a gsr trans i dont want to go ls but i want to be able to get atleast 140-145 in 4th gear. so a couple of guys adviced me on doing ls 3-5 with gsr final drive, would'nt it be better to just get an ls final drive on the gsr gears. anyone with experience on either of these set-ups?what do either of these set-up run on the top of 4th gear (mph wise) on a 24" tire.What should i do.
YES I'VE SEARCH
Old Feb 22, 2013 | 08:15 PM
h22apwrd95's Avatar
Default Re: transmision ??????????????
What will max RPM be?
Old Feb 22, 2013 | 08:16 PM
gpr's Avatar
gpr
Default Re: NEED YOUR ADVICE
9K. what setup yields more mph
Old Feb 22, 2013 | 08:29 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
My advice
Take this topic and move it to the proper forum aka transmission forum
Old Feb 22, 2013 | 08:34 PM
h22apwrd95's Avatar
The LS 4th on a 4.4 final drive with a 9K rpm rev limit should yield you around 154mph on a 24.5. The GSR 4th in the same setup would net about 10mph less.
The straight GSR trans on the LS FD, all other factors the same, would split the difference between the other two boxes. It should put you in at 149mph in a perfect world.
Old Feb 22, 2013 | 09:09 PM
gpr's Avatar
gpr
thanks guys for the time and help. found this
http://www.zealautowerks.com/transcalc.php
OneBadTurboCRV
Guest
Posts: n/a
There is NO WAY you even remotely searched. First link that Google provided...
http://www.teammfactory.com/gear-calculator
cheesebeast
Transmission & Drivetrain
Dec 8, 2011 07:33 AM
diablo2184
Apr 13, 2011 08:48 AM
Pandahatch
Feb 22, 2007 03:14 AM
JDMKid71
12
Oct 25, 2006 09:35 AM
b20vtecEK
Jan 25, 2005 05:27 AM
