Need Uberdata Rom for B16A Turbo
Hi
Just getting the lst part before fitting the turbo and i need a reliable uberdata map to put on there to keep me going for a while.
I have
RevHard Turbo Manifold
T3/4E turbo
Tial Wastegate (.5bar)
XS Power FMIC
440cc Precision Injectors
OBD1 Conversion + Chipped ecu
Please has anyone got simular setup running uberdata rom they don't mind sharing with me.
Also can you really run 10 PSI safely on a standard engine and how?
Bobby
I have
T3/4E turbo
XS Power FMIC
Bobby
i got a b16 w/ 450cc's running 6-7psi on a pretty small turbo (6 psi it made 227whp)
email me at kgooman@gmail.com
The only real way you can safely run off a "basemap" is to run a wideband oxygen sensor in the car & monitor the true air fuel ratios.
You also need to sync your ignition timing at the distributor so that you do not end up running a shitload of ignition timing etc.
With a basemap which puts you in the target a/f ratios and has a conservative timing map you should be ok
