need some info about engine harness
Old Jul 29, 2002 | 02:24 PM
98civicEX's Avatar
Default need some info about engine harness
well after looking over my dyno sheets i realized that my spiking occured w/ my vtec crossoer point. knowing this my buddy is just doing a complete dx block build up in his obd2 civic. was wondering if i we can reuse the engine harness that is for a vtec, and it'll work "plug n play" wise with his complete dx motor. i'm assuming it should plug in and the vtec wire shouldn't have a problem...thanks in advance for the info.
Old Jul 29, 2002 | 02:48 PM
PrecisionH23a's Avatar
Default Re: need some info about engine harness (98civicEX)
you'll throw codes.
Old Jul 29, 2002 | 03:35 PM
HXMan's Avatar
Ummmm...you talking about using the OBD2 ex harness on a DX engine? Should work perfect if you use a DX ecu. You just won't hook up the VTEC wires or knock sensor wires.
Old Jul 29, 2002 | 04:01 PM
98civicEX's Avatar
Default Re: need some info about engine harness (HXMan)
perfect thanks
skill178
Jun 29, 2013 06:25 AM
Joacnel
Aug 25, 2012 03:53 AM
ordny6
Apr 19, 2008 07:27 AM
eg_junior
Jan 16, 2007 06:24 PM
Slick2126
Apr 2, 2006 05:03 AM
