NEED TURBO MANIFOLD FOR CLEARANCE OF TURBO HOUSING
I made a post earlier and I currently have a log style turbo manifold and it doesnt stick out far enough away from the block and the turbo housing keeps hitting it. Already shaved down some of the block and we are so close to getting it on. Anyone have an idea of a good manifold that would have the turbo flange sticking out further away from the block? Thanks
Moderator
Re: NEED TURBO MANIFOLD FOR CLEARANCE OF TURBO HOUSING (BOOSTEDgs-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEDgs-R »</TD></TR><TR><TD CLASS="quote">I made a post earlier and I currently have a log style turbo manifold and it doesnt stick out far enough away from the block and the turbo housing keeps hitting it. Already shaved down some of the block and we are so close to getting it on. Anyone have an idea of a good manifold that would have the turbo flange sticking out further away from the block? Thanks </TD></TR></TABLE>
I've mentioned this on Xceed. The only other solution is to use Spoolin' performance (should work) but it depends upon if that ebay turbo of yours is using a larger compressor cover. Otherwise, get a head flange and longer bolts as suggested on Xceed.
1baddturbosi
06-14-2007 09:18 AM
Danger
07-05-2003 09:35 AM
