Is This a good head gasket for my civic
http://cgi.ebay.com/ebaymotors...ZWDVW
this is a gasket on ebay that i found that is for turbo applications and was wanting to know if its worth it or if there is another gasket out there i should get i have already blown a head gasket once and i need to know if this will work or not im running 15lbs any help please
Re: Is This a good head gasket for my civic (jarven093)
That would be a retarded idea to buy that. They dont even list any specs on how thick it is. Stick with oem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarven093 »</TD></TR><TR><TD CLASS="quote">well i have blown a oem head gasket already thats why im looking for another </TD></TR></TABLE>
well then you didn't install it right or you had a bad tune
Re: Is This a good head gasket for my civic (SOHC_MShue)
Hondapartsdeals.com, look at the 96-00 Ex section, engine, then cylinder head.
$23.84, and probably under $30 total shipped to your door. I've done 10psi/big turbo on a d16z6 w/*reused* oem mls headgasket. FTW
The only way you really can blow an OEM msl gasket is by running way too much timing, way too much heat (coolant stops flowing), or your head/block is warped to some degree.
Eghatchgsr8
09-19-2014 02:24 PM
Joeski99Si
04-22-2009 09:57 PM
