Which head gasket?
Old Oct 13, 2008 | 01:02 PM
victoriasamantha's Avatar
Default Which head gasket?
What is the best head gasket to use for a turbo car?
i have used cometic before and didnt have no problem with it.
also someone told me that golden eagle uses factory honda head gaskets.
thanks
Old Oct 13, 2008 | 01:36 PM
Schister66's Avatar
Man U FTW
OEM Honda HG's are used pretty regularly. Another good one (from what i've heard) is Cometic. I have no first hand experience with the latter though...
Old Oct 14, 2008 | 11:43 AM
Default Re: (Schister66)
anyone else know?
Old Oct 14, 2008 | 01:53 PM
CerealKiller's Avatar
Default Re: (victoriasamantha)
did you search? topic has been discussed before. OEM all day.
Old Oct 14, 2008 | 03:47 PM
yakuza's Avatar
Had the same dilemma and majority said OEM. Went finally with OEM victor Reinz MLS ... So far 300 miles on the new build and running perfect.
Old Oct 14, 2008 | 07:48 PM
TheShodan's Avatar
Moderator
Default Re: (yakuza)
OEM will be fine.
If you could, bring ALL of your questions in as few new threads as possible. we don't mind helping out a lot of questions on one thread that you make, please.
Old Oct 15, 2008 | 01:06 AM
Default Re: (TheShodan)
thanks, looks like i will go oem. you may delete this thread if possible. is it possible to have a stock head gasket cut out to 84mm
Old Oct 15, 2008 | 06:22 AM
srmofo's Avatar
sure is, IF you have the equipment to do it, It ISNT a DIY job....thats exactly what golden eagle does....I've used OEM headgaskets on my turbo LS now for years without any problems...and I plan on using a golden eagle head gasket on my 84mm lsv-t that I am currently building....You can use a b20 HG if you are in a bind
Old Oct 15, 2008 | 10:01 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victoriasamantha &raquo;</TD></TR><TR><TD CLASS="quote">thanks, looks like i will go oem. you may delete this thread if possible. is it possible to have a stock head gasket cut out to 84mm</TD></TR></TABLE>
You can try, but it won't matter because you'll need to sleeve the motor to get 84mm. If you can afford that, you don't need to waste time on "making" a gasket.
Old Oct 15, 2008 | 11:16 AM
i meant can a shop do it. i have 2 new b16 head gaskets sitting here and cant sell them for $30 each. I thinking instead of letting them sit there use them.
thanks
Old Oct 15, 2008 | 11:31 AM
srmofo's Avatar
first off, what is your setup?
Jaydeep
24
Aug 5, 2013 09:43 PM
young geezer
Dec 16, 2010 09:04 PM
Maddman7887
Sep 16, 2009 09:33 AM
Christopherian1982
Jan 22, 2009 05:38 PM
eg6cusco10pt
May 31, 2004 10:14 AM
