Need quick answer?????????? please
Old Feb 15, 2002 | 12:54 PM
silo's Avatar
Default Need quick answer?????????? please
my friend has a zex nitrous kit on an 1997 civic ex and has been spraying the 65 shot with no problems with 4 degrees of retard..we just finished installing a GSR fuel pump and are curious if we need to try an up the fuel pressure to use the 75 jets , will the pump alone give enough fuel for this setup?? because he hasen't the money to buy a regulator so we can flood it with fuel.
thanx alot
Old Feb 15, 2002 | 01:06 PM
silo's Avatar
Default Re: Need quick answer?????????? please (silo)
tt
Old Feb 15, 2002 | 09:22 PM
silo's Avatar
i would just like to say thanx for all the help you guys ......................
heh
Old Feb 16, 2002 | 08:59 AM
downpipe's Avatar
i think you should try calling "zex."
Old Feb 16, 2002 | 09:01 AM
immortal's Avatar
Banned
heh
help yourself now.
Old Feb 17, 2002 | 12:50 AM
HKxBlur's Avatar
my friend has a zex nitrous kit on an 1997 civic ex and has been spraying the 65 shot with no problems with 4 degrees of retard..we just finished installing a GSR fuel pump and are curious if we need to try an up the fuel pressure to use the 75 jets , will the pump alone give enough fuel for this setup?? because he hasen't the money to buy a regulator so we can flood it with fuel.thanx alot
Immy, be nice!
I had enough fuel on my 75shot setup with my DX pump.. Now I have the Walbro (BBK) 255lph pump and my fp is set at 50psi (stock was at 46psi).. Get the cheap fuel press regulator and gauge just so you can be sure not to fk anything up.. The stock pump AND the gsr pump will both be enough, however I recommend u know the pressure before u start getting crazy..
hondaeg8
Sep 19, 2004 03:19 PM
TSACIVICSIK20A
Dec 2, 2003 07:21 PM
hybridlsvtec
Feb 3, 2003 06:18 PM
little red crx
Sep 14, 2002 02:41 AM
