Need quick answer?????????? please
my friend has a zex nitrous kit on an 1997 civic ex and has been spraying the 65 shot with no problems with 4 degrees of retard..we just finished installing a GSR fuel pump and are curious if we need to try an up the fuel pressure to use the 75 jets , will the pump alone give enough fuel for this setup?? because he hasen't the money to buy a regulator so we can flood it with fuel.
thanx alot
thanx alot
my friend has a zex nitrous kit on an 1997 civic ex and has been spraying the 65 shot with no problems with 4 degrees of retard..we just finished installing a GSR fuel pump and are curious if we need to try an up the fuel pressure to use the 75 jets , will the pump alone give enough fuel for this setup?? because he hasen't the money to buy a regulator so we can flood it with fuel.thanx alot
I had enough fuel on my 75shot setup with my DX pump.. Now I have the Walbro (BBK) 255lph pump and my fp is set at 50psi (stock was at 46psi).. Get the cheap fuel press regulator and gauge just so you can be sure not to fk anything up.. The stock pump AND the gsr pump will both be enough, however I recommend u know the pressure before u start getting crazy..
