Need input on GSR turbo setup
Here is the planned setup on stock internals to run 7-8 psi daily driven GSR:
T03/T04E Turbo
Inline pro exhaust manifold
Tial 35mm external wastegate
HKS SSQV BOV (or Greddy Type S..help?)
Stock GSR IM
P72 94/95 gsr ecu
obdI-obdII conversion harness
hondata s200 w/ boost
some kind of fmic (need help here)
IC piping
2.5" downpipe
440 or 550 saturated injectors (need help here too)
Walbro 255lph-HP in tank fuel pump
Turbo XS high performance manual boost controller
fuel lines
new oil pan gasket
OBDII conversion clips for injecters (no resitor box stuff)
oil feed and return lines
Gauges:
boost, egt, fuel pressure
Other stuff:
ACT clutch (need help here)
ES motor mounts
Those are all the parts I'm looking into right now...is there anything that I'm missing...any parts I've chosen that you have an issue with? Any suggestions or helpful comments?
Once i decide on the parts of the setup then I'm going to start researching prices etc so help me settle on the seutp first - thanks in advance!
Also, is this setup good for gsr's top heavy powerband?
EDIT: good prices and places I can find that stuff is also appreciated
Modified by lustedp at 5:45 PM 5/10/2003
T03/T04E Turbo
Stock GSR IM
P72 94/95 gsr ecu
IC piping
2.5" downpipe
fuel lines
new oil pan gasket
Gauges:
Other stuff:
ES motor mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo »</TD></TR><TR><TD CLASS="quote">get the injectors from viren. B18bturbo. Great seller fast shipping!
i paid $206 shipped for my saturated 550's</TD></TR></TABLE>
do I need the larger injectors...i don't plan on upgrading my setup once it's installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lustedp »</TD></TR><TR><TD CLASS="quote">
do I need the larger injectors...i don't plan on upgrading my setup once it's installed.</TD></TR></TABLE>
You never know man
. Besides you're going to be using hondata so you can control it with no problem.
You never know man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pope »</TD></TR><TR><TD CLASS="quote">hey lustedp, let me know when you're down figuring out how much all this is going to cost</TD></TR></TABLE>
will do. I have an excel spreadsheet with the costs but of course its incomplete so far.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lustedp »</TD></TR><TR><TD CLASS="quote">will do. I have an excel spreadsheet with the costs but of course its incomplete so far.</TD></TR></TABLE>
thanks, because i plan on havin a daily driven, stock internal gsr sometime down the road.
just outa curiousity, what has been priced and whats the total so far?
thanks again.
thanks again.
almostboostedgsr
Feb 13, 2007 12:37 PM
Osokwik
Apr 8, 2005 09:12 PM
