Need some technical help. (*Zzzzzip, Puts on flame suit*)
I'm finishing up the turbo project and have 2 more things to purchase. Before I begin, here's my current setup:
Car: 1999 Civic Si
Current bolt-on's:
- '00 ITR cams, IM (w/ Hondata gasket), TB, and valve springs
- Hondata S200 w/ 3 step
-ACT flywheel w/ Exedy stage 1
- ES mounts and Silver's engine damper(don't flame; works great)
- 3" header-back exhaust
- Oil temp, oil press., EGT, Boost, Fuel pressure and water temp. guages
-Moroso baffled oil pan w/ turbo return
-Walbro 255 pump
Current Turbo parts in waiting:
-Blox maniflod
-Tial 38mm WG w/ 90deg elbow
-Greddy BOV + turbo timer
Waiting to buy:
-Turbo
-Intercooler setup
- Quaife (not now though.... )
Getting to the point, I need to purchase a turbo and IC to complete this project. I know the manifold is for a T3 setup and because I haven't built the bottom end I'm only going to boost ~7-8psi. I need some insight as to what turbo will best suite my needs. I'm also not planning on draging this car. Mostly I want a good mid-high turbo setup for weekend driving (my car only has 27,XXX miles on it). I want to get this done before the end of May and need to know what turbo (Comp. .XX A/R and Turbine .XX A/R specs) I should be purchasing. It's all a little confusing to me. I also have to make sure it fits my manifold (Keeping A/C by the way )
Car: 1999 Civic Si
Current bolt-on's:
-Walbro 255 pump
-Blox maniflod
Waiting to buy:
-Turbo
-Intercooler setup
Re: Need some technical help. (Osokwik)
This is a good option: http://www.importparts.com/sho...=5947
a 57 trim turbine will fit you well with a nice .63 or so AR compressor housing to make some good high end still. It will spool quick and still have good pull on the top end. I liked my SC34 for that reason.
Re: (Osokwik)
no not to small, but with the higher rev of that motor it may die out alittle bit in the high end...still a solid choice though if you're not looking for big numbers
Re: Need some technical help. (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com »</TD></TR><TR><TD CLASS="quote">This is a good option: http://www.importparts.com/sho...=5947</TD></TR></TABLE>
That looks nice ben and the price is also right .....
Can you choose a v band turbine housing instead of 5 bolt with that gt30R? How much does it run extra?
