.::need info on 86mm gsr::.
Old 02-14-2005, 06:40 PM
kevino002's Avatar
Default .::need info on 86mm gsr::.
has anyone run the big a bore on a street car? just wondering I saw in the all motor forum that people had problems with head gaskets sealing? any info would help. btw mine is a darton sleeved 86mm gsr block.
Old 02-14-2005, 06:41 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: .::need info on 86mm gsr::. (kevino002)
i wouldnt for fi on anything over an 84.5mm bore. to liitle material left on the slleves, yes even if it s sleeved
Old 02-14-2005, 06:44 PM
kevino002's Avatar
there seems to be alot of materail left on the sleeve, darton garentees the sleeves will hold 30+ psi.
Old 02-14-2005, 07:31 PM
kevino002's Avatar
Old 02-14-2005, 07:50 PM
_entropy's Avatar
We tried 85.5 on a friends B16. Didn't hold HG's worth crap, and it started to see blowby not long after we got it running, I think the cylinders became out of round. I would sell the block and start fresh, or have it resleeved.
Old 02-15-2005, 12:59 PM
T4eg's Avatar
Default Re: .::need info on 86mm gsr::. (Napoleon Dynamite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Napoleon Dynamite &raquo;</TD></TR><TR><TD CLASS="quote"> I would sell the block and start fresh, or have it resleeved.</TD></TR></TABLE>
I agree the biggest we run turbo motors are 84.5mm.
Chris
Old 02-18-2005, 04:58 AM
kevino002's Avatar
Default Re: .::need info on 86mm gsr::. (BlueHatch00)
Thats not what I wanted to hear. lol
I think that I will try and see what happens, it I have problems then I will just start over.
Old 02-19-2005, 06:45 AM
kevino002's Avatar
for more info
Old 02-19-2005, 09:31 AM
Luke J's Avatar
DO it and let us know how it works out.
Old 02-19-2005, 10:00 AM
kevino002's Avatar
Default Re: .::need info on 86mm gsr::. (Lucky925l)
I will..
Old 02-20-2005, 02:22 PM
asubennett's Avatar
When you do it, have the machine shop use a torque plate to do the hone. It will keep the cylidners more true. - A good guy on this board gave me that very helpful tip. There are a few guys in the all motor forum running 87mm bore on a B Series.. Just make very sure both surfaces are flat as possible.
B19 coupe also had luck with indian head gasket sealer. I am anxious to here out it goes.
My 86mm motor shoul dbe done tommorrow night.
Old 02-21-2005, 11:47 AM
kevino002's Avatar
Default Re: .::need info on 86mm gsr::. (asubennett)
The block is at the machine shop as we speak should be done friday. I will let you all know how it goes.
Old 02-21-2005, 12:05 PM
PIFFSTAR's Avatar
my block is bored out at 85.5mm with dart MID sleeves i'm currently in the break in period, rev limiter set at 5000rpm 5pds of boost i put about 3000k on the motor since it was built.... just waiting on some $$$ to go tune but, going to play it safe keeping the boost at 10pds when i tune..but i'm making plans to build another block tho. i just have a slight feeling that block is going to go PINNNGGGGGG!!!!!!!!!!!!
Old 02-21-2005, 12:07 PM
kevino002's Avatar
Default Re: .::need info on 86mm gsr::. (PIFFSTAR)
well I guess we will see, eveyone at the shop says that it will be fine that I am just worring about it to much.
Old 02-21-2005, 03:02 PM
asubennett's Avatar
I agree. I think a lot of people shy away from 86mm becasue they are told it is impossible.
I too was scared in the beginning because of what I heard. The only con is that you at your limit so if something does break it doesn't leave much room for correcting it. I would not be afraid to boost like on the 86 just as you would on a 85 or an 84. If it blows the gasket then dial back the boost.
Old 02-21-2005, 03:11 PM
kevino002's Avatar
see thats what I wanted to hear, thanks for the support asubennett.
Old 02-21-2005, 07:54 PM
asubennett's Avatar
Best of luck to you. Rememebr that flat surfaces are your freind. take some material off the deck of the block if you have to.
Old 02-25-2005, 05:46 AM
kevino002's Avatar
Old 06-15-2005, 09:39 AM
kevino002's Avatar
well I finally got the car on the street. I took it to the dyno and found out that I need to replace the coil and one of the spark plug wires was bad so I just got a MSD 6Al and some MSD plugs. I went back to the dyno about a week later and was only able make one pass, the injector on #4 cyle. was not working, so I make just under 300whp at 6-8psi with only 3 cylenders. I am going to replace the injectors this week and get it back on the dyno. I have put about 500 miles on it boosting 6-8psi before the injector went. will update soon.
Old 04-15-2006, 01:48 PM
kevino002's Avatar
Have been running the motor for about 6 months on 8-9psi and have had no problems with the HG, going to the dyno soon to tune for higher psi and more power, will keep you updated.
Old 04-15-2006, 02:21 PM
I've quit using this account
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevino002 &raquo;</TD></TR><TR><TD CLASS="quote"> so I make just under 300whp at 6-8psi with only 3 cylenders.</TD></TR></TABLE>
who in CO is tuning it?
you should contact servion (he is on here) , he is the man iin CO for tuning hondas
tell him Kelly sent ya
Old 04-16-2006, 03:48 PM
kevino002's Avatar
Default Re: .::need info on 86mm gsr::. (Kelly.)
He is tunning my car... Has been since I switched from Hondata to Neptune.
Old 04-16-2006, 07:05 PM
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevino002 &raquo;</TD></TR><TR><TD CLASS="quote">He is tunning my car... Has been since I switched from Hondata to Neptune.</TD></TR></TABLE>
JFG Kevin
09-06-2006 09:22 PM
hondachris1994
04-07-2006 03:10 PM
marcussmith26
12-22-2005 07:36 PM
lak8
06-05-2005 11:53 PM
joepiscapo_83
04-13-2005 01:41 PM
Quick Reply: .::need info on 86mm gsr::.
