Running lean with nitrous!
Old Mar 6, 2006 | 01:48 PM
Azn Kenny's Avatar
Default Running lean with nitrous!
Got a 96 LS, i/h/e and a NOS dry kit (75 shot)
I have the basics, NGK BRK7E (2 step colder) plugs, retarded timing 3 degrees, and a B&M adj. fpr set to ~40 psi at idle.
It seemed to run great while spraying, no hesitation or excess smoke but when I checked the plugs they were a little white, which tells me I'm running lean.
Can anyone help me out here? Should I bump up the fuel pressure? Thanks.
Old Mar 6, 2006 | 02:00 PM
TypeSLO's Avatar
Default Re: Running lean with nitrous! (LSntegra)
umm...i think you mean one heat range colder. stock is 6 range. show pic of plug.
Old Mar 6, 2006 | 02:02 PM
Azn Kenny's Avatar
You're wrong, my stock heat range is 5.
I'll post a pic when I get out of work.
Old Mar 6, 2006 | 02:07 PM
nonvtecallmotor's Avatar
Default Re: (LSntegra)
use ngk zfr6's and put your timing back to stock. retarding your timing will cause it to run leaner
Old Mar 6, 2006 | 02:15 PM
splitime's Avatar
Are you doing a pull and IMMEDIATLY turning the car off and drifting to the roadside to check the plugs? If not... you'll be seeing lean conditions because the car normally runs on the lean side for cruising and idle.
Old Mar 6, 2006 | 02:18 PM
TypeSLO's Avatar
heh, sorry, i thought u were in a b16...
Old Mar 7, 2006 | 06:56 PM
nx h22's Avatar
here is your fix do a wet shot and then you wont run lean
jnasty
Feb 2, 2007 02:44 PM
JDM H22
Jun 17, 2005 02:54 PM
cliff666
Nov 14, 2003 10:18 PM
TURBO B
Aug 1, 2003 10:43 AM
lsteggy
Dec 17, 2002 04:01 AM
