need help w/ turbo setup
Old Aug 12, 2002 | 01:23 PM
ACURACY_VTEC's Avatar
New User
Default need help w/ turbo setup
what's up guys, i'm going to install a turbo soon & i need to know what parts i need. so far a have:
-1g talon turbo
-ic
-downpipe
what will i need to make this setup work on a jdm b16a
thanks
Old Aug 12, 2002 | 02:51 PM
ekb18c's Avatar
Default Re: need help w/ turbo setup (sweet-teg)
-1g talon turbo
-ic
-downpipe
thanks
Well your going to need :
exhaust manifold
all the piping
bov
wastegate
some sort of fuel managment (fmu, 255lph fuel pump)
steal braided line for the oil to the turbo
get our oil pan ready for the oil return line. (drill and weld )
That should be it. Did i forget anything?
Old Aug 12, 2002 | 04:49 PM
New User
Default Re: need help w/ turbo setup (ekb18c)
exhaust manifold
all the piping
bov
wastegate
what part of the motor should i tap into for oil to turbo line?
the stock turbo on 1g talon has a wastegate
Old Aug 12, 2002 | 05:07 PM
B18EG6's Avatar
on the back of the block, where the oil pressure sensor is. The sensor has a nipple, with one wire leading off of it. Either tee it off and keep the stock sender, or just get rid of the stock sender for the "idiot light"
Old Aug 12, 2002 | 05:11 PM
T25 civic's Avatar
Default Re: need help w/ turbo setup (B18EG6)
Would it hurt anything to just get rid of the stock sensor? Will the oil light on the bezel be on all the time?
Nick
Old Aug 12, 2002 | 05:33 PM
KiddEng's Avatar
Default Re: need help w/ turbo setup (T25 civic)
ur gonna need to keep the sensor, other wise why would honda put it there?
all u gotta do is get a tee thats a 1/8 male, 1/8 female, 1/8 female it sorta looks like a block of brass with the male part sticking out and 2 female holes. its simple to connect ur oil line/ sensor back onto the block. don't mess with leaving the sensor out.
good luck
peace
Old Aug 12, 2002 | 05:34 PM
genop's Avatar
I dont use the oil sensor and I dont get any weird lights or anything.....
Old Aug 12, 2002 | 08:38 PM
jdblack1's Avatar
Default Re: need help w/ turbo setup (genop)
why not have the sensor? I kept my stock unit and instead of a T' I used a cross and $12 sunpro manual oil psi gauge. The more sensors on a turbo car the better IMHO.
Old Aug 13, 2002 | 11:11 AM
New User
Default Re: need help w/ turbo setup (jdblack1)
thanks for all the reply's. just one more thing, how much hp & 1/4 mile do u think i could get with my set-up.
thanks
EKris
May 15, 2007 09:58 PM
andreysibiris
13
Jan 17, 2006 12:03 PM
projectPSI
Dec 5, 2004 12:12 PM
EJ1_519
Mar 22, 2004 07:13 AM
pub
Dec 2, 2002 07:13 PM
