need help? plz!
Old May 5, 2007 | 03:32 AM
rod64's Avatar
Default need help? plz!
hey guys its been a while since i last posted...anyways I'm not sure if this is the right place to post my question but here it goes. Recently my car got broken into and they stole some important stuff. Mainly my hondata s200 w/ boost option and my obd1 p72 ecu. My question is that since my car is boosting, can I run a stock obd1 or obd2 ecu for a while till I find a replacement? will it be safe? BTW i have a 99 gsr if that helps.....Also I could use some advice...like should I just upgrade to a hondata s300? I know this might seem to be a stupid question but I'm a noob at this so plz no flaming...thx again!
Old May 5, 2007 | 03:47 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: need help? plz! (rod64)
just drive it normal, if you arent running a map check valve the car will yell at you when you get into boost, so just be easy and yes you can drive it. gm 3 bar? if so you may have to swap it back to the stock map.
Old May 5, 2007 | 03:58 AM
rod64's Avatar
thx for the reply...btw im boosting at 10 psi w/ stock map sensor....so it should be ok? just drive like my grandma? hahah
jfoster
Apr 12, 2011 04:42 PM
chasetheskate
Jun 2, 2007 01:52 PM
crush
Jun 5, 2005 12:16 PM
Linus_E
Mar 29, 2005 09:07 AM
are_sicks
Feb 12, 2002 06:48 PM
