Need help with plugs!! ASAP
Old Feb 10, 2004 | 01:28 PM
GDM Z28's Avatar
Default Need help with plugs!! ASAP
i just bought new plugs for my LS-T and i usually use the ngk BCPR7ES-11 but the shop was out of them , so they gave me the BCPR7EVX-11 instead because they are the same heat range and everything. only difference is the plugs i just got today are the platinum ones. Can/Will this hurt my motor? ive never used the platinum ones so i just wanted to make sure. please let me know asap cause i need to put them in so i can finish tuning my car. TIA
Old Feb 10, 2004 | 01:33 PM
GaDawgs's Avatar
i thought platinum plugs were really good. they are they same heat range? my GUESS is that they would be good.
Old Feb 10, 2004 | 01:42 PM
GDM Z28's Avatar
Default Re: (GaDawgs)
well i was told by someone that he thought he heard that the platinum plugs werent too good for the car. i just wana make sure. any other input?
Old Feb 10, 2004 | 01:44 PM
redboost10's Avatar
Default Re: (civicflnum1)
i know iridium plugs are very bad for cars running nos, but i thats all i know
Old Feb 10, 2004 | 01:49 PM
GDM Z28's Avatar
Default Re: (tgh99si)
wheres all the FI masters?
Old Feb 10, 2004 | 02:24 PM
GDM Z28's Avatar
can someone with alot of knowledge in FI just tell me if they are safe or not?
Old Feb 10, 2004 | 04:00 PM
GDM Z28's Avatar
TTT
Old Feb 10, 2004 | 05:03 PM
markaria's Avatar
darn good question... Ive heard bad things on platinum plugs fot fi as well...bump
Old Feb 10, 2004 | 05:07 PM
Group Tenacity's Avatar
Default Re: Need help with plugs!! ASAP (civicflnum1)
Unfortunately i cant help much, but i do noe platnum plugs are no good for nitrous. i melted the electrodes off a set on my old motor.. had to re bore the motor and replace the valves because the melted platnum went eveywhere and made a mess of things...
I would think they wouldnt be good for boost either if they melt so easy.. i only had a 50 shot of nitrous and they melted, just imagine what would happen with 10+psi of boost...
Old Feb 10, 2004 | 05:15 PM
redboost10's Avatar
Default Re: Need help with plugs!! ASAP (Group Tenacity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunately i cant help much, but i do noe platnum plugs are no good for nitrous. i melted the electrodes off a set on my old motor.. had to re bore the motor and replace the valves because the melted platnum went eveywhere and made a mess of things...
I would think they wouldnt be good for boost either if they melt so easy.. i only had a 50 shot of nitrous and they melted, just imagine what would happen with 10+psi of boost... </TD></TR></TABLE>
same thing happened here except i was using $50 iridium plugs, it sucked
Old Feb 10, 2004 | 06:18 PM
GDM Z28's Avatar
Default Re: Need help with plugs!! ASAP (tgh99si)
well i just called up one of my friends who knows quite a bit about FI and he said that the platinum plugs are fine for FI. im gonna try em and see what happens
SPOOLINmatt
Nov 6, 2005 07:49 AM
Drew Peacock
Feb 13, 2003 08:28 AM
Etylorcen
Jun 21, 2002 05:59 PM
