NEED HELP PLEASE!!
Old Oct 28, 2009 | 04:58 PM
jsongkhamdet's Avatar
Default NEED HELP PLEASE!!
My car studders at vtec or when i get into full boost around 4500-5000 rpms...happend out of nowhere...changed out the spark plugs still doesnt fix the problem...the setup is a boosted jdm gs-r (b18c)...any suggestions?? let me kno...thanks!!
Old Oct 28, 2009 | 05:18 PM
project dc2's Avatar
Default Re: NEED HELP PLEASE!!
need to know more about your setup
what turbo setup ? brand ? what mods do you have ? ecu tuning ? fuel management ?
Old Oct 28, 2009 | 05:26 PM
57 trim turbonetics turbo...on a stock 94 jdm gsr b18c...vortec FMU
Old Oct 28, 2009 | 06:09 PM
someone please help...
Old Oct 28, 2009 | 06:55 PM
jsilva's Avatar
by studdering are you talking about its breaking up? or is it bogging? could be many things. Coil,dizzy, fuel issue etc. You need to be more specific about the issue and also i see you say its on crome but is it tuned properly?
Old Oct 28, 2009 | 08:46 PM
well i found out that my ECU is running LIMP MODE...tryin to figure out what could have caused this problem...i do have a CEL and is throwing code 8 which is tdc sensor (top dead center)...car has been tuned for over a year now and has never had a problem until now...i do have msd ignition 6AL with a msd blaster coil and msd 8mm wires...what would cause me to be running in limp mode??
Old Oct 29, 2009 | 08:27 AM
neone??
Old Oct 29, 2009 | 09:24 AM
champLSinteg's Avatar
You tuned it on crome and fmu? Stock injectors?
Old Oct 29, 2009 | 09:33 AM
i jus opened up my ecu and dont see a chip in it soo i guess it isnt tuned...but yea im running the stock injectors...never had this problem till now...
Old Oct 29, 2009 | 09:37 AM
i bought the car the way it was...
Old Oct 29, 2009 | 09:57 AM
imationdawg's Avatar
check your engine oil level. add some oil and i bet your problem goes away
Old Oct 29, 2009 | 10:06 AM
Ill check it out...hopefully the problem goes away!! Thanks for the suggestion...
Old Oct 29, 2009 | 10:10 AM
Jus check oil and it seems to be fine...
Old Oct 30, 2009 | 11:29 AM
jsilva's Avatar
you need to take it to a shop and have them tune it an troubleshoot it. Its obvious you dont have a clue as to whats wrong so i suggest you take it to someone who does before you blow it up.
Old Oct 30, 2009 | 12:00 PM
jdm inc's Avatar
^^ agree get an engine managment and get rid of that fmu and get it tune. or something bad is gonna happen.
Old Oct 30, 2009 | 01:21 PM
NonovUrbizniz's Avatar
Loved
Guys it's been running fine for a long time he says... if the FMU wasn't set up right it wouldn't have been working and he already would have blown the engine... is it ideal... NO... is it fine to use YES.
If you're throwing a TDC sensor code... chances are your TDC sensor is either broken or there's a problem in the wiring... I'd check that first... clear the code and go from there.
Chances are that's your problem.
extremeracer
Engine Management and Tuning
May 7, 2012 10:59 PM
Ntense90crxsi
Jul 10, 2008 02:38 PM
92HB_HB
Apr 15, 2004 12:50 PM
civicr97
Feb 26, 2004 08:36 AM
