Need help with 2 step setup with MSD billet dizzy setup?
Old Jul 8, 2008 | 01:02 PM
Ntense90crxsi's Avatar
Default Need help with 2 step setup with MSD billet dizzy setup?
I am currently running a MSD digital 6 box but I am switching to a MSD billet setup with module. There is really no need for the box other then the 2 step which I do still need to retain but I don't want to have a $400 2 step if you know what I mean. What other alternatives would I have to retain a 2 step with just the MSD billet dizzy and module so I can get rid of the new digital 6 I have? Thanks guys.
Old Jul 8, 2008 | 05:26 PM
A train's Avatar
Default Re: Need help with 2 step setup with MSD billet dizzy setup? (Ntense90crxsi)
we use both in lisa car and it is perfect just keep an eye on the rotor and cap! the digital 6 has more functions than just the 2 step! try you will be impressed the wiring is actually real easy pm me if you need any help!
Old Jul 8, 2008 | 07:08 PM
Default Re: Need help with 2 step setup with MSD billet dizzy setup? (A train)
Yea I heard about the rotor screws coming out with some of the allen heads. Needless to say all of the screws will be getting some locktite before it goes into the car. I forgot to mention I am also running a FAST system and I am having some AEM type of misfiring problems with the stock dizzys. Hopefully this will clean up the signal to the FAST and will fix this dreadful miss I can not seem to beat.
Old Jul 8, 2008 | 07:17 PM
swapit's Avatar
if your using fast just use the msd dizzy and a hvc coil with the digital6 and dont use the ignitior,im doing that with my aem right now and no issues.works as if i had a t1 cam trigger.
Old Jul 8, 2008 | 07:44 PM
Default Re: Need help with 2 step setup with MSD billet dizzy setup? (swapit)
The FAST will not read a straight hall effect style signal it has to be inductive from what I understand. I was told the module is what actually converts the signal from hall effect to a inductive style so a stock computer or the FAST will understand it. Please correct me if I am wrong because I won't run the MSD module if I don't have to.
Old Jul 8, 2008 | 07:49 PM
The only reason I went this route with the MSD billet is because Tony1 told me his cam trigger would not work with the FAST setup or I would already of ordered it to fix my signal issues. With the MSD converting the signals this seemed to be my only other alternative.
Old Jul 9, 2008 | 06:15 AM
So are there any 2 step setups you can wire to a stock setup?
Old Jul 9, 2008 | 01:37 PM
So does anybody got any ideas if I get rid of the digital 6 for a 2 step setup?
Old Jul 9, 2008 | 01:48 PM
Turbo-charged's Avatar
ive never used fast, but i would assume there would be a 2step feature in the software?
Old Jul 9, 2008 | 02:41 PM
Default Re: Need help with 2 step setup with MSD billet dizzy setup? (Turbo-charged)
Unfortunately there is not a feature for a 2 step with FAST.
Old Jul 9, 2008 | 08:27 PM
tepid1's Avatar
WHich FAST system are you using? Old or the XFi?
Old Jul 9, 2008 | 08:33 PM
tony1's Avatar
Default Re: Need help with 2 step setup with MSD billet dizzy setup? (tepid1)
The old one. No bells and whistles at all.
Old Jul 10, 2008 | 12:26 AM
Default Re: Need help with 2 step setup with MSD billet dizzy setup? (tony1)
Yea the old one and it is as basic as it gets on features. I mean overall it is a great system, easy to use, doesn't give me any other issues other then hating stock Honda distributors and not being very versatile with options. Jason Hunt's car went mid 9's with it though and I believe Brian Ballard was running the same thing back in the day. There are just so many more options now but I would hate to completely switch systems mid season. I have had this system for 3 years and just finally finished my build this year so I have set on it for some time. After talking to Tony1 I may be going Motec this winter when the car goes back down with one of his cam trigger setups, definately nice stuff!
Old Jul 10, 2008 | 02:38 PM
I will installing the MSD dizzy setup this evening. Hopefully it will fix my misfire problems I have had with the FAST and stock dizzy's like it does with the AEM guys. Keep your fingers crossed!
lostforawhile
Jun 7, 2014 10:42 AM
93grayeg
Jan 24, 2013 10:47 AM
midnite_B16
Feb 11, 2007 08:13 PM
TRE_
Aug 24, 2003 11:40 AM
