Need help picking a turbo
Old May 24, 2008 | 12:10 AM
  #26
joe111599's Avatar
i will let turbodano give some insight but i THINK the s360 and 362 spool almost identical. a lot of people on here are running the s366 in their street cars saying they spool like a 35r. why not have a little bigger turbo(s362) thats not working quite as hard and still spools the same? know what i mean? not to mention if you ever want to go past the 500 mark then you have the right turbo.
Old May 25, 2008 | 09:24 AM
  #27
acrocat's Avatar
can someone help explain to me the differences between the s360 and the s362 ?
Old May 25, 2008 | 07:11 PM
  #28
TheShodan's Avatar
Moderator
Default Re: (acrocat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acrocat &raquo;</TD></TR><TR><TD CLASS="quote">can someone help explain to me the differences between the s360 and the s362 ?</TD></TR></TABLE>
Both turbos are mid to high end units that are made for EASILY over 600whp, but may be a bit laggy for what you're looking for. The question that YOU have to ask yourself is HOW you want the type of power that you're looking for, and whether or not your displacement will assist you in that power, response, and torque that you're looking for. I've found that though these units are comparable and larger than the Precision SC series, they can do serious damage on the streets in the top end, but it may be a bit much...This is where understanding your purpose comes into play, and only YOU can answer that.
Old May 26, 2008 | 08:30 AM
  #29
Schister66's Avatar
Man U FTW
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
Both turbos are mid to high end units that are made for EASILY over 600whp, but may be a bit laggy for what you're looking for. </TD></TR></TABLE>
I'll second that. Although the S3xx series is a great grouping of turbos, i think they're a little larger than what you'll want for a stock sleeve street/strip car. I'm still sticking with my suggestion of the S256/S258. They'll spool like a 57 trim and are still capable of nearly 600whp (the highest i've seen was 558whp). That would be my pick...and if you check my sig, it already is my choice
Old May 26, 2008 | 08:53 AM
  #30
acrocat's Avatar
So i'll probablly end up either going with the s258 or the s360
Old May 27, 2008 | 01:11 PM
  #31
TheShodan's Avatar
Moderator
I'd say S258 or S362, because they are available in the smaller S200 compressor cover, to have a much better fitment for a higher variety of manifolds.
bonesx0x2x4x
Nov 14, 2010 09:34 PM
killablaze
Nov 23, 2005 02:52 AM
b18c1wes
Apr 5, 2005 06:29 PM
fast94ex
Oct 8, 2004 01:02 PM
