need help picking a good 1/2 size radiator
Old Feb 12, 2006 | 02:38 PM
ALL IMPORT's Avatar
Default need help picking a good 1/2 size radiator
what are the best radiators to go with on my 96 teg. & do they make some that bolt right up?
Old Feb 12, 2006 | 05:02 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
Default Re: need help picking a good 1/2 size radiator (ALL IMPORT)
i don't know if you can make it work for your car, but i put a Fluidyne for 99-00 Civic Si in my hatch and it gave me 16 degrees cooler at highway speeds and 7 degrees cooler at idle. i used datalogging on my hondata to get the numbers... oh this is with 2.0 ls vtec
idle
before: 191
now: 184
highway
before: 188
now: 172
also after some beefing at 12 psi going from 65-130 about 4 times the temp only rose 1 degree
Old Feb 12, 2006 | 05:20 PM
ALL IMPORT's Avatar
Default Re: need help picking a good 1/2 size radiator (BrokeAssWhiteboy)
this isnt a daily driver i will be running 35lbs boost at the track & when i am on the street it will be around 20lbs
Bsmith1010
27
May 15, 2019 07:23 AM
pilot355ces
Jul 22, 2009 05:48 AM
DirtyBirdJR
May 3, 2005 07:55 AM
95hatchfire
Sep 29, 2004 11:38 AM
EG6owner-T
17
Jul 6, 2003 08:59 PM
