need help..... motorola 2.5 map sensor and MBC
Old Sep 2, 2008 | 11:42 PM
black_ek's Avatar
Default need help..... motorola 2.5 map sensor and MBC
Modified by black_ek at 10:42 PM 9/3/2008
Old Sep 3, 2008 | 08:05 AM
HiProfile's Avatar
Default Re: need help..... motorola 2.5 map sensor and MBC (black_ek)
Using an MBC would mean your MAP sensor has nothing to do with boost issues. Its only job is to tell the ECU how much pressure the manifold sees. If it was an EBC controled by your ecu's EMS, then that part of your EMS uses the map signal to tell it what PSI to go to.
Sounds like you hooked it up wrong. An MBC only needs the vac line to go from pressure area (mani, turbo) to the lower port on the WG, with the MBC in that line. The top should remain empty. Otherwise you'll see MAX boost, since the pressure in the top port will FORCE the valve closed 100%.
Old Sep 3, 2008 | 01:06 PM
black_ek's Avatar
Default Re: need help..... motorola 2.5 map sensor and MBC (HiProfile)
Old Sep 3, 2008 | 09:42 PM
black_ek's Avatar
never mind...it was some vacum problems..its all fix
mod delete this
Ldo
Oct 9, 2010 03:35 PM
1994delsolLS
Oct 5, 2009 01:13 PM
EJ8 GSR-T
Feb 19, 2007 09:11 PM
wanabecivicex
Dec 18, 2002 08:28 PM
