map sensor question
map sensor question
i am planning to go with a simple turbo setup and only plan to run 7 psi at max most likley will run 5 psi. will the stock map sensor be ok to use at 5-7 psi? btw its an 0bd1 integra ls motor
Man U FTW
Re: map sensor question
TO THE OP: Before you turbo your LS and settle on a pressure goal, you should read through the Forced Induction forum. You'll soon see that pressure is not the basis for measurement that we use. The only true indication of potential (and engine safety) is the amount of whp created. This is because 7 psi on a 16g and 7psi on my S256 are vastly different things. I suggest you read through and learn a little before jumping head first into anything.
Hope this helps
I have to agree with Schister66 on everything he said and give props for actually taking the time to break it down for you guys like he did, cause I wasn't going to do it, lol. So hats off to u Schister for the schooling of the noobs.
Man U FTW
Well people have to learn somehow and unless they were each to take time individually to go through the Forced Induction FAQ, none of them would know exactly how it works. Plus, i've been either really busy or super bored lately...the above post was during one of my super bored stages
stock map sensor can handle 10.84 psi of positive pressure. anything over that it can't read.
