Need help with mbc install
Old Aug 14, 2010 | 10:22 PM
spoon93's Avatar
Default Need help with mbc install
ok i have a turbonetics manual boost controller that im trying to install on a 91 LS turbo EF, my question is where do i run the boost pressure sensing connection line to? heres the pic of the boost controller and a pic of the directions i got with it.... let me know what you guys think. thanks h-t
File Type: pdf
Old Aug 14, 2010 | 10:23 PM
spoon93's Avatar
Default Re: Need help with mbc install
click bottom link to see installation instructions....
Old Aug 15, 2010 | 06:52 AM
habib's Avatar
T it off to the line that goes to the bottom of your wastegate as it shows in the directions or run it to your intake manifold
Old Aug 15, 2010 | 09:26 AM
spoon93's Avatar
Ok I was confused cause it says make sure it's dwn stream of throttle assembly
Old Aug 15, 2010 | 12:57 PM
spoon93's Avatar
Anyone else have a pic of one hooked up
Old Aug 15, 2010 | 01:03 PM
cbustuner's Avatar
. Either tap the intercooler piping or compressor housing. I had one of these and it worked great when it was hooked up correctly.
Old Aug 15, 2010 | 01:32 PM
spoon93's Avatar
Ok nice thanx that helps alot
Old Aug 15, 2010 | 01:35 PM
spoon93's Avatar
Also could I t it off on the charge pipe like a inch away from the throttle body or is that too close I also have a brass fitting on the turbo itself on the housing idk let me know thanks for the help guys
Old Aug 15, 2010 | 04:16 PM
cbustuner's Avatar
Use the fitting off the housing.
Old Aug 15, 2010 | 04:25 PM
spoon93's Avatar
Koo sounds good thanks bro
boostek9
Jun 9, 2010 06:52 PM
B18C_EJ8
Feb 23, 2008 03:10 PM
hondamonkey
Nov 24, 2007 03:55 PM
Marlon88
May 8, 2006 06:44 PM
TurboTeG4
Sep 18, 2004 10:43 AM
