need help with mbc install
put the wastegate on its own line seperate from the bov... if your boost controller is a bleed type its gonna make your bov vaccuum refrence source weak. causiing the bov to not work properly
Am I to assume you're running w/o a boost gauge? If you aren't, and don't have it tuned to the psi its at now, you could be SOL. Its possible the noise diff is from different boost pressures between various mbc placements, but your descripion of the noise ('weird') is useless for even educated guessing.
