fluttering noise when i shift gears?
Old Nov 26, 2001 | 06:16 PM
psicrxsi's Avatar
Default fluttering noise when i shift gears?
what are the possiblities that this could be? my car was impounded and i jes got it back today. i can hear the bov but it wasnt like it was b4(use to be a nice wapst sound). i only sort of hear it at high rpms.
Old Nov 26, 2001 | 06:41 PM
turbocoupe's Avatar
Default Re: fluttering noise when i shift gears? (psicrxsi)
you could be surging. . .what kind of BOV is it?
Old Nov 26, 2001 | 06:54 PM
BoostingGSR's Avatar
You might be leaking boost
Old Nov 26, 2001 | 07:56 PM
psicrxsi's Avatar
Default Re: fluttering noise when i shift gears? (BoostingGSR)
its a greddy type-s. i dont think im leaking any boost. my mbc is set at 8lbs of boost.
Old Nov 26, 2001 | 07:58 PM
psicrxsi's Avatar
theres a little thing rite next to/below where the vacuum tube goes.....is this suppose to be plugged up? (its a little shinny silver thing sticking out). i also have a tial 35mm wastegate too. any help to solve my problem would be appreciated.
Old Nov 26, 2001 | 07:59 PM
psicrxsi's Avatar
oh..when i was talking about that shinny thing i meant it was on the blow off valve
Old Nov 26, 2001 | 09:18 PM
turbocoupe's Avatar
You can put the vaccum hose on either on of the "metal thingys"or nipples on the BOV it doesn't matter. . .serves the same purpose. . .hmm type s that's the same one I have and I've always have had that fluttering sound. . .kind of like the HKS super sequential. Then again my turbo blew last week. . .rebuild is on the way. . .thank God for Majestic.
Marc
[Modified by turbocoupe, 12:18 AM 11/27/2001]
Old Nov 26, 2001 | 10:42 PM
paulzy's Avatar
Default Re: fluttering noise when i shift gears? (turbocoupe)
have you readjusted your BOV yet? try that...worked for me.
Old Nov 26, 2001 | 11:59 PM
SagaGSR's Avatar
Default Re: fluttering noise when i shift gears? (Slow_ass_4dr)
take a look at your vacuum lines. mine flutters at low rpm (below 3k) but after 3k i get a high pitched whistle
Old Nov 27, 2001 | 01:49 AM
MiraiZ's Avatar
Default Re: fluttering noise when i shift gears? (SagaGSR)
read this article for more details on compression surge and why its bad
http://www.c-speedracing.com/faq/07.html
Old Nov 27, 2001 | 06:00 AM
VTC_CiViC's Avatar
Default Re: fluttering noise when i shift gears? (MiraiZ)
The upper most nozzle sticking out of the Greddy BOV should be attached to a vaccum source, the lower most should be left open, it acts as a vent for the diaphram (according to GReddy).
leinadmiih00
Feb 7, 2007 04:26 PM
calib17a
Apr 14, 2004 08:58 PM
Trac226
May 25, 2002 07:20 AM
turbogsr13z
Apr 7, 2002 09:32 PM
FBP Si 2000
Feb 7, 2002 07:21 AM
