NEED HELP!!! LS VTEC FULLY BUILT TURBO SETUP!!!
I need help, I have the following below and I need to know if I should put it a blockguard or will I be fine? or will the blockguard do damage rather then good? Bottom is all assembled. I was told that I might need to insert a block guard? Also do they even make a blockguard for my app. 1.8L with 2.0L sleeves. Will it be okay as it is to make 20 psi and 450 whp max be daily at 12 psi? YES NO? advice help?
91 B18A1 LS bottom
Darton open deck sleeves CRV 2.0L
Crower pro billet rods
JE 20 over 2.OL pistons rings pins
Polished crank
balanced
Got a fully built LS head for sale $1200 obo extras $1450
90 day project coming soon!!!
Modified by ExplicitSpeed at 10:14 PM 6/10/2004
Modified by ExplicitSpeed at 1:06 AM 6/11/2004
91 B18A1 LS bottom
Polished crank
balanced
that sleeve install dosent look to hot, see the space between the sleeves
but usually when a block is sleeved, then you dont want to run a block guard.
Landon
.but usually when a block is sleeved, then you dont want to run a block guard.
Landon
I agree with boosted_dc2, if your block is already sleeved then you would not want to put a blockguard.
It just does not make any sense ya know.
I am using a blockguard cause I can't afford a sleeved block.
ya there iron ductile I think and the bore is 84.5mm, It was done by a well known shop in San Diego, CA that works on imports so I am sure that they are put in fine. I just needed reinsurance that they will be okay up to 20 psi max without a blockguard added. It's either do or die...
Modified by ExplicitSpeed at 1:07 AM 6/11/2004
there not that thin, may look it, but there 20 over on CRV and Darton sleeves can take I think as far as 80 over and still have the same power band and strength. AZ came up with a blockguard for me he was kinda like either way about, if you want it to be bullet proof put one in...but i know people who dont and there fine...so i think I will not get the blockguard. I dont plan on goin over 20 psi, so I should be good I am thinkin....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB »</TD></TR><TR><TD CLASS="quote">my 84 mm bensons look thin like that too..</TD></TR></TABLE>
Mine doesn't.
Mine doesn't.
If I had a choice I would gotten the Darton closed deck, I got the block for cheap so of course I'll take it and make dew.
ExplicitSpeed
Jun 10, 2004 03:59 PM
leadfoot78
Dec 9, 2003 03:06 PM
b18bturbo
May 12, 2003 07:32 AM
