Need Help with First Build
Old May 6, 2012 | 07:29 AM
  #26
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Need Help with First Build
If you installed a new cam and didn't adjust the valve lashing then that is def your problem. The slack in your valves is causing the cylinder to not be able to build compression. Calidad just rebuilt a z6 and was told it was already rebuilt but all the valves were bent and not building compression.
vtecsi00
10
Feb 25, 2008 06:44 PM
88crx
Mar 6, 2006 08:56 AM
Will_H
Apr 18, 2004 03:49 AM
Mr. Lonely JDM 4dr teg
Aug 13, 2003 07:38 AM
LB CRX
Jun 24, 2002 08:15 AM
