HELP!! Car wont start after cams are installed.
Old Aug 12, 2003 | 01:01 AM
Mr. Lonely JDM 4dr teg's Avatar
Default HELP!! Car wont start after cams are installed.
well i place in some new cams today and after we were done the car wont start anymore. it made a puff puff sound and a ehhhhhhhhhh sound. iunno if the cams are moving or not but i will find out tomorrow. can anyone help me out here.
Old Aug 12, 2003 | 01:03 AM
@ries's Avatar
who put the cams in???
Old Aug 12, 2003 | 01:37 AM
Default Re: (emoBB1)
we did.
Old Aug 12, 2003 | 01:54 AM
Kamin's Avatar
Default Re: (96 GSR BOY)
um
was everything set at TDC?
did you use lots of assembly lube?
Old Aug 12, 2003 | 02:21 AM
Default Re: (Kamin)
yup yup everything was right at TDC and use AL
Old Aug 12, 2003 | 05:54 AM
Stubbs's Avatar
on some aftermarket cams the distributor can be put on 180 out of phase(at least on the b18A/B) check that out
Old Aug 12, 2003 | 07:26 AM
Buzzbomb's Avatar
Default Re: (Stubbs)
yeah, I bet your distributer is 180 off, been there, done that.
Old Aug 12, 2003 | 08:44 AM
irev210's Avatar
Default Re: (Buzzbomb)
definitly sounds like you have issues with timing. When u did a valve adjustment, did u do it in the correct order aswell?
check the 180...
check the valve adjustment
Old Aug 12, 2003 | 09:29 AM
rsbad454's Avatar
Default Re: (irev210)
from his name GSR boy id say he has a VTec motor but not sure..........better double check timing alignment.............
Old Aug 12, 2003 | 02:02 PM
Default Re: (rsbad454)
well im about to check all of that again and let you guys know what happens
Old Aug 13, 2003 | 03:19 AM
00 FBP ItR's Avatar
Default Re: HELP!! Car wont start after cams are installed. (96 GSR BOY)
ALL FIXED...
They finally decided to call me up..
I came to the rescue...
Old Aug 13, 2003 | 05:22 AM
rsbad454's Avatar
Default Re: HELP!! Car wont start after cams are installed. (00 FBP ItR)
what was the prob?
Old Aug 13, 2003 | 05:54 AM
Default Re: HELP!! Car wont start after cams are installed. (rsbad454)
one of the guys who i was working oon it forgot to do the TDC on the pistons. ahaha. dont know if that made sense.
Old Aug 13, 2003 | 07:23 AM
00 FBP ItR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR BOY &raquo;</TD></TR><TR><TD CLASS="quote">one of the guys who i was working oon it forgot to do the TDC on the pistons. ahaha. dont know if that made sense.</TD></TR></TABLE>
Let me clear it up for you...
Before they removed the cams.. they forgot to set it to tdc before removing the cams.
It "skipped" his mind.. LOL!!
So we just removed the timing belt, crank the motor by hand to find tdc(screwdriver in the sparkplug hole). and reassembled.
Modified by 00 FBP ItR at 9:36 AM 8/13/2003
Old Aug 13, 2003 | 07:38 AM
rsbad454's Avatar
well there you go.................timing issue..............
lifeschase
Honda CR-V & Element
May 28, 2016 09:03 AM
123delsolman
Jul 3, 2010 08:25 PM
slowredsol
Jan 22, 2009 11:43 PM
Dave_Dc2
Nov 27, 2008 07:42 AM
drunknbass
Aug 1, 2004 09:52 PM
