Need Help, BOOSTING PROBLEMS while Smashing it
Old Aug 13, 2009 | 07:57 PM
xlasianizelx's Avatar
Default Need Help, BOOSTING PROBLEMS while Smashing it
alrite so i got the car running, not 100% fully tuned but safe to run for now?....
so far im boosting 7psi according to my guage but, the problem im experiencing is that, when smashing on it, i can hit 7psi maxed at 5000 rpm
but it sounds like a rev limiter on the turbo, i guess its spluttering like a long woosh sound (and im 100% forsure its not the bov)
what could be wronG?
manual boost controller problem?
Old Aug 13, 2009 | 08:19 PM
tegman23's Avatar
Default Re: Need Help with b16a2 turbo vacuum lines
Dont take the car into boost...and make sure you have your wastegate vacum hooked up..
Old Aug 13, 2009 | 08:25 PM
i am not sure where to hook it up to.... im not trying to boost for sure until i get a good tune
Old Aug 13, 2009 | 08:37 PM
da_dude's Avatar
If your turbo have a nipple on the compressor housing than connect a vacuum line from that to your wastegate. If you have a manual boost controller than that goes on the vacuum line from the turbo to the wastegate. Boost gauge "T" with fpr and the bov to the other vacumm source that on top of the manifold like you mention in your first post. That should be good until your vacuum manifold arrive.
Old Aug 13, 2009 | 08:44 PM
my turbo housing does have a nipple but it was capped off, and i was told to run the boost controller from a port on the side port of my tial wastegate, leaving the top port opened, and i t-ed it with a port directly on top of the intake manifold, whast am i suppose to be doing?
its pretty confusing
Old Aug 15, 2009 | 11:18 AM
Default Re: Need Help, BOOSTING PROBLEMS while Smashing it
bump
Old Aug 15, 2009 | 12:07 PM
K i l l a B e e.'s Avatar
if its cutting off it might be because the car is tuned too rich.
make sure you hook up your wastegate right too.
Old Aug 17, 2009 | 05:14 PM
desiromeo812's Avatar
where r u planning on gettin it tuned at?
Old Aug 17, 2009 | 07:14 PM
frogg5872's Avatar
If you do not know how to route the wastegate vacuum then how do you plan to tune it? Sounds like your doing it yourself bc .its not "completely" tuned and your still driving it "smasking" the gas?! SOunds like disaster.
But sounds like you may have the wastgate vacuum backwards.
Old Aug 17, 2009 | 07:17 PM
boost4s2k's Avatar
sounds like someones gonna get a new car soon huh?
Old Aug 19, 2009 | 09:15 PM
ok... the previous owner had the turbo kit on a D-Series tuned to 14psi, it made 260whp, so when i had it on my car it was particially tuned already, since the d16y8 and a b16a2 isnt too different. the only problem was that the previous owner had it at 14psi and i was only running 6psi.
I already retuned the car, it was done at TECH3 Performance, Ryan the tuner was very helpfull and good at what he does. Unfortunantly i was only able to boost 6.5-7psi because of a really worn out MSD Cap and Rotor.. my car kept cutting out power (misfiring) ar 6-7k rpm so ryan just set it at 6.5psi. it made 240 whp w/ 160lbs torque
i was hoping for more but im pretty satisfy with it already,
Lao17
Apr 2, 2011 05:28 PM
turbo sol
Mar 1, 2009 08:47 AM
krazyhmongboi
Mar 30, 2008 12:44 AM
jdm-ray
May 15, 2005 09:37 PM
TheHatchHog
Sep 24, 2004 11:47 AM
