Need help BAD, was doing a compression test and..
Old Dec 5, 2002 | 08:06 PM
geminis2k's Avatar
Default Need help BAD, was doing a compression test and..
The adapter that comes with it is stuck in my cylinder head. Any ideas how to get it out? I bought the tester from AutoZone, it came with a gauge, hose, and then the adapter - My friend and I connected the adapter not knowing we didn't have to and it got stuck. I'm hoping we're not the only people out there that have gone through this so if anybody out there has some answers, please help!! The adapter is still threaded, but we can't get it out the same way we got it in (the hose)...
Old Dec 5, 2002 | 08:14 PM
littlebluecrx's Avatar
Default Re: Need help BAD, was doing a compression test and.. (Alex)
I cant picture what you mean , but I wonder if you took some fuel hose that was smaller forced it on the adapter with screw driver or needle nose and then slowly try to twist it out? Jason
Old Dec 5, 2002 | 08:22 PM
gsrstyle's Avatar
oh man, that happend to me. i got it out by putting the hose back in REALLY TIGHT, then slowly loosening it.
good luck man
Old Dec 5, 2002 | 08:25 PM
HonaTek1's Avatar
I've done that...Try putting "locktite" on it then let it sit for a long time then try removing it
Old Dec 5, 2002 | 08:31 PM
crxhybrid1320's Avatar
Default Re: Need help BAD, was doing a compression test and.. (HonaTek1)
That happens alot it seems. You some oil or lubercate with long needle nose.
Be carfull not to rip the hose though.
Maybe next time try not to put it very tight
[Modified by crxhybrid1320, 5:17 AM 12/8/2002]
Old Dec 6, 2002 | 02:15 AM
niedejb's Avatar
Default Re: Need help BAD, was doing a compression test and.. (crxhybrid1320)
Can you take the gauge off the hose?
I had the same prob. Took the gauge off, slid a larger ID hose down over the smaller hose. Press down and turn on the larger hose and it should come out.
Old Dec 6, 2002 | 02:28 AM
PrecisionH23a's Avatar
You dont need to screw the tester in that tight, just snug and you are good. This happened to me before. Here is what you do.... Spray a little wd-40 in there to loosen up the adapter. Then take i believe either a 18,19, or 20mm deep socket with 6" extension and you'll need to put pressure on the adapter while turning. Hopefully the pressure will allow the adapter to spin, thanks to the wd40 loosening things up a bit. If that fails, put a spark plug into the adapter, same thread pitch. Then use a long flathead screw driver to hold the adapter in place, then tighten the spark plug, not allowing the adapter to spin, then very quickly loosen the spark plug. Hopefully this will spin the adapter loose. Make sure you didnt damage the o-ring on the adapter, if so it will yield fucked up compression numbers. Good luck.
Old Dec 6, 2002 | 06:40 AM
legendboy's Avatar
Default Re: Need help BAD, was doing a compression test and.. (GudeH23a)
I took the long handle of my chanel locks (with nice thick cooshy grips on the ends) stuck it inside the opening of the adapter pushed it down real hard and slowly started turning it out as I applied as much pressure to one side as possible. It came right out.
Old Dec 6, 2002 | 06:51 PM
geminis2k's Avatar
Default Re: Need help BAD, was doing a compression test and.. (legendboy)
what r chanel locks?
Old Dec 6, 2002 | 08:48 PM
legendboy's Avatar
sp
Old Dec 7, 2002 | 05:17 AM
trbob16a's Avatar
Like needle nose pliers, except much bigger and instead of going to a point they stay flat. They also "lock" into place.
hometheaterman
Apr 3, 2010 10:44 AM
vegas hoe
Feb 16, 2008 05:06 AM
T-RO
May 15, 2003 08:53 PM
Eluzion
Dec 8, 2002 10:33 PM
geminis2k
Dec 5, 2002 09:13 PM
