GM 3 Bar Map sensor!!!
Old Sep 26, 2002 | 06:31 PM
Boostless97Lude
Guest
Posts: n/a
Default GM 3 Bar Map sensor!!!
i know i saw a thread somewhere, sometime, that mentions the part numbers from GM for the 3 bar map sensors and wire connector, but i couldn't find it with a search. does anyone know what ehy are???
also, does anyone have any pic of them installed?
Old Sep 26, 2002 | 06:44 PM
MiraiZ's Avatar
Default Re: GM 3 Bar Map sensor!!! (Boosted97Lude)
I think http://www.hondata.com ha a whole step by step page on this...
Old Sep 26, 2002 | 06:57 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: GM 3 Bar Map sensor!!! (MiraiZ)
yeah, they used to, but now i can't seem to find it on their site anywhere... i don't know WTF is up
Old Sep 26, 2002 | 07:26 PM
bmm89's Avatar
3bar MAP sensor: GM #16040749
Old Sep 26, 2002 | 07:32 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: GM 3 Bar Map sensor!!! (bmm89)
what about the plug to match up to it???
Old Sep 26, 2002 | 08:32 PM
bmm89's Avatar
they do not make the pigtail anymore, not one that fits anyway, though i here one can be modified to bit...
Old Sep 26, 2002 | 09:15 PM
MiraiZ's Avatar
http://hondata.com/3barinstall.html
there ya go...you can get the plug from F-MAX (if they're willing to sell it separately)
Old Sep 26, 2002 | 09:34 PM
Boostless97Lude
Guest
Posts: n/a
i'd kinda like to see pics of how it's installed on the car too if anyone has them
Old Sep 26, 2002 | 10:56 PM
Civic Power's Avatar
New User
This should help
http://www.Gmpartsdirect.com
these should be it:
gm 3 bar map sensor # 16040749 ($49.08)
harness: #12085502
Old Dec 6, 2002 | 01:22 PM
accordfreak's Avatar
Default Re: GM 3 Bar Map sensor!!! (Civic Power)
can someone check the stamped part number on the back? i want to make sure i got the right map sensor....
on the back where it's stamped "GM" it says "466"
and
on the back of the connector where it's stamped "A,B,C" , are numbers stamped "460 8211".
please verify.. thanks!
Old Dec 6, 2002 | 01:42 PM
legendboy's Avatar
Default Re: GM 3 Bar Map sensor!!! (accordfreak)
I'm on the same hunt. I've looked everywhere for information. GM is useless. I also have 2 that have the 466 stamp and 460 xxxx numbers and green plug incerts.
Old Dec 6, 2002 | 01:59 PM
ekb18c's Avatar
Default Re: GM 3 Bar Map sensor!!! (legendboy)
Be carefull when purchase GM 3 Bar map sensors! There are just so many of those damm GM 3 bar maps. What are you planning to use the 3 Bar map with???
If you are going to use it for Hondata then you have to get the one from them. Believe me!!! I tried so many different 3 bar maps. I went out and bought 4 different maps and only one worked with Hondata.
If however your using the 3 bar maps for other systems then I think all are good. However my 3 bar map save 748 on the back, it's either 748 or 749. Sorry I have bad memory.
HTH
edit - you can buy the plug for the 3 bar map at any local pep boys or parts store. They cost $1.50 for the plug, remember these are generic GM parts so anyone will have them.
[Modified by ekb18c, 11:02 PM 12/6/2002]
Old Dec 6, 2002 | 05:06 PM
BudaKai's Avatar
Default Re: GM 3 Bar Map sensor!!! (ekb18c)
Where can I get the voltage maps for them? You know so I can make my fuel maps in accordance to the voltage and whatnot.
Old Dec 6, 2002 | 05:11 PM
sweet's Avatar
i went to my local shop to look up the GM 3 bar MAP sensor, they had #735-13201 off the shelf. i've seen so many #'s being stated about finding the correct MAP sensor to use with the Hondata system.
is it better just to spend the extra $$ and get the MAP from Hondata so i know it'll work correctly?
what model GM vehicles do these MAP sensors come in? only the older, 80's models or the newer ones too?
some have gotten GM MAP's from their local stores and they say the ones they got work fine.
thanks
Old Dec 6, 2002 | 05:46 PM
MiraiZ's Avatar
Default Re: GM 3 Bar Map sensor!!! (sweet)
I waana know how to get it to work with the powerFC
Old Dec 6, 2002 | 10:52 PM
up
Old Dec 7, 2002 | 05:26 AM
Boostless97Lude
Guest
Posts: n/a
i know a couple guys that have GM 3 bars on their RX-7s with a Power FCs, i can ask and see if they had to do something special to make them work
young geezer
Aug 1, 2009 12:44 PM
crx1856
Aug 31, 2003 01:58 AM
CiViC SiR
Jun 26, 2003 08:54 PM
CiViC SiR
Jun 18, 2003 05:50 PM
philo
Dec 3, 2002 08:37 AM
